Repetier Server printer conf
Hi!
I just installed repetier server. There’s an option to upload the printer configs directly to the server… Saves the hassle to set everything up. Where can I get this file?
If you have already installed the repeater server then you should know some of the valid steps which can be specified by the process of the repeater easily and then the entire settings of the printer should be changed and that can be made by the blog of the Epson printer recovery mode to generate the settings by yourself.
Sure… Doesn’t answer my question
