I just assembled a K8200 printer last week. But when I was trying to connect the printer with my laptop, there shows 1 command waiting. This is the screen shot.
I’m sure that all the values are correct and all the cables are connected properly. Is there any one met the same problem?
[quote=“BrianH”]I just assembled a K8200 printer last week. But when I was trying to connect the printer with my laptop, there shows 1 command waiting. This is the screen shot.
[quote=“ichbinsnur”][quote=“BrianH”]I just assembled a K8200 printer last week. But when I was trying to connect the printer with my laptop, there shows 1 command waiting. This is the screen shot.
I would be very appreciated if you can help.
Brian[/quote]
Did you try resetting the printer?[/quote]
Yes, I reset it many times and there is still 1 command waiting.
To started fixing the problem by re-installing the Arduino program Marlin - Arduino 1.0.6. on my arduino board, and ran the k8200 dedicated K8200 Repetier-Host V0.95F which is downloadable from a link at K8200.eu.
I was receiving waiting commands AFTER the bottom left hand corner said I was connected with the right COM port.
I opened my Arduino program Marlin - Arduino 1.0.6. then opened/uploaded my Marlin.ino and found 2 different BAUDRATE font shades under the tab Configuration.h.
I changed both, and the system worked. I am printing as normal.
Key note: When you click “Verify” to check the code, make sure your Repetier Host program is NOT connected, or you will get an error.
The image attached is the screen shot.
I find that sometimes the image is not available on forums, so I also posted the direct link of the image which is hosted on my website below.
