Hi
Is baudrate 500 000 only speed delta is allowing?
For a 500000 baud rate to actually work properly, the printer needs to support native USB rather than Serial COM communication, as well as using a very high quality cable to prevent increased error rates
What driver you recommend to pc?
My Repetier can connect to Delta, but everytime i press “connect” buttom, Delta is restrating.
Repetier is connected after restart, allowing control.
This happens every time pressing connect
Jukka
