Repetier 1.6 Run on Pause
Replaced Repetier V0.95F with V1.6.0 I use the pause facility to change filament, putting code to move the extruder into the ‘Run on Pause’ box in the g-code editor.
I can find no such box in 1.6
If it has been removed is it present on the 1.5 or will I have to go back to 0.95?
Go to manual control there you will find the G-code field.
I found it. Printer settings (top right) scripts tab.
