hello is that sb can explain to me how to use the latest version of repeat-host with the printer, I tried but could not connect with imprimmante Version 0.90c
You need to install a driver before using the printer. You can see on this manual link how to do :
k8200.eu/manual/printing/?c=002
The driver works well it recognizes the printer on COM6 and works perfectly in Repeat-host 0.84, the question is how to make it work in Repeat-host 0.90c?
The correct software is called Repetier-Host. Do you get any kind of error or message when you try to connect? Is Repetier configured for the correct COM port?
Instructions for Repetier-Host 0.90C can be found here:
k8200.eu/news/?id=810
Fill in the correct COM port when following the instructions
ok it’s work fine now with your configuration, thank you very much !
