Relay Time and Reset VM 201
Hello Velleman Support, I have a problem with the card relay VM 201, I have programmed schedules relays, when it is ON and make a change in the network configuration, the card is reset and return to normal state work, the relay should be activated because it is within the established time period, but this mode is OFF. This is the “About” it shows me the card:
Ethernet Relay Card
Build: 1236
Build date: Sep July 2012 8:56:42
TCPIP Stack: v5.42
There any possibility to resolve the problem?
thank you very much
More information about this problem for Velleman Support:
I updated the firmware to: Build 1342 (the last update)
When I turn on the power the card the display show:
THU 1 Jan 1970
1:00:00
I change the NTP Server to:
hora.roa.es and I have also tested es.pool.ntp.org
GTM +1 Madrid
And I Saved
Date and Hour in display not change.
And starts counting (example):
THU 1 Jan 1970
1:09:13
If Iturn off the power and reconnect the power the display is:
THU 1 Jan 1970
1:00:00
