A relay contact is a “dry” contact; This means that no voltage is coming out!
The contact is completely separated from the circuit and can be used in your application without risk.
Usually the contact has two positions, using one common contact:
NO: Normal open (Closed when relay is activated)
NC: Normal closed (Open when relay is activetad)
