I would like to use a Tyco T92 Series Relay in conjuction with the K8055 I/O Board. I the coil load in 1.7w at 12VDC. The design would be the positive side of the coil is attached to CLAMP and the negative lead goes to Dig. Out 1.
Do you see any issues with this relay?[i
