So I finally installed my ramps 1.4 I wired everything up and everything seems to be working but the y axis it won’t move. I have checked the wiring and everything seems ok. Is there a way to test the stepper motor driver to see if it is faulty? or are they any other thing I should try first. Thanks guys
I’m not that familliar with the ramps, but to check the drivers simply swap them with a on known good.
X and Y for example. If the problem moves with the suspect driver it is faulty or incorrectly tuned.
[quote=“ichbinsnur”]I’m not that familliar with the ramps, but to check the drivers simply swap them with a on known good.
X and Y for example. If the problem moves with the suspect driver it is faulty or incorrectly tuned.[/quote]Well the stepper motor drive seem to work fine but for some reason the y axis just isn’t moving. When I turn on the machine and the first time i try to move it it moves about 1 mm and then won’t move anymore. I have triple checked the wiring all good there. I am just stumped!
Did you try it in the opposite direction?
Maybe you wired the endstop incorrectly.
[quote=“ichbinsnur”]Did you try it in the opposite direction?
Maybe you wired the endstop incorrectly.[/quote]Yes have checked the endstop wiring as well? Not sure what it could be any other ideas?
Does it move away from the end stop or to it?
[quote=“Wrong Way”]Does it move away from the end stop or to it?[/quote]No neither. When you first start the machine up and ask it to move it nudges .01mm then won’t move anymore…
Any endstop hit or such messages in the log?
