Hi is it possible for for a ghost or spirit box to be made so that it would cater for those interested in the paranormal field.
This would help and give the user a cheaper option
ie like kit mk118 or mk194 made to sweep the channels bit with a speed control so that the sweep could be adjusted. The paranormal field is the fastest growing movement and i would lije to see vellman produce a kit.
Sorry, we have no experience with ghost detection. What frequency range does the average ghost use?
Basically you sweep the radio full range frequency 88 to 108 like adding a function generator to produce a triangle wave. This gives you control so it will sweep slow to fast. i.e. using kit 23 op amp circuit with the lm324n chip. Your older kit mk 118 works well with this circuit making it a ghost box. Please reproduce your mk118 kit many in the paranormal field want them. Or could you make a kit with both on one board.
This is hilarious " Average ghost "
