Hello!
I’ve built an amplifier I use for acousting building measurement (insulation measurement) with n. 12 (4 ohm) fullrange loudspeakers (dodecahedron loudspeaker) with a k8084 preamp. I used 2 k8086 module. Every module drives 6 of the 12 loudspeakers. This 6 loudspeakers are in serie/parallel configuration (three pair in series, every pair made by 2 loudspeaker paralleled) 6 ohm total.
Instead of two 120VA trafo I used two 225w velleman trafo with just a little problem about fuse (both 1A fuse, blew every time turned off the amplifiers - probably caused by higher magnetizing current of bigger trafo). with 1.6A all is ok.
I made some test with pc sound card and pink noise to know max power capability of amps+dodecahedron. Short session (15 sec.) with 3/4 potentiometer and 1 session (7 sec.) at max power. I was outside, in the garden, Temperature was 5° C, heatsinks were cold. After 2 hours I was beginnig last test…sound card connected to amplifiers (pre k8084), NO SIGNAL, I turned potentiometer to max…only much background noise produced probably by pc circuits… and 2 second of big noise like “HUM” and both fuse blew and poth amplifiers blew…
Before this test, I made 1 hour test with pink noise, half way potentiometer, and 50 watt , 5 ohm resistences in the amplifier outputs…heatsink hot and resistences very very hot, but everything allright.
Bias was befor setting at 10mw (cold amplifier).
I changed tip142, tip147 and bc547 , now both amplifier are ok.
Made new test like before, but without pc, playing pink noise with cd player.
No problems.
Have you an idea about what appened ? I’m shure everithing is all right (soldering, components etc…)
May be pc background noise cause amplifier oscillating??? -
200watt isn’t enough. I was thinking to add 2 more k8060 module , 4 k8060 in total and each one for 3 loudspeaker (6 ohm).
Can every channalel of K8084 preamp drive 2 k8060?? -
I have read only 1 k8060 for 1 trafo, the only problem is “hum”? In this case I could try… (I used 225w instead of 120w trafos)
During session measurement with pink noise I have to use every time very high sound pressure level (about 100dB Lp(A)) so hum is not a problem bacause is impossible to hear it .
thank’s a lot and sorry for my English…
alessandro angelini, Italy.
