Push button function on the VM201
I miss a push button function on the VM201. I would like to use it to control dimmers. short press = dimmer on / off . Long press = dim function. Work with timers seems to me not an option. I just want to be able to set up a button that follows the relays in the app. Is this possible?
Sorry, there is momentary function.
Sorry, there is not.
I bought the VM201 because it should be there, but there is no option to pulse with the press of a button.
There is a pulse option within the timer section, but that is not what Dipsy means! And not what I searched.
Just like the on/off button in the status screen there should be a pulse button.
Or better, a configuration setting that let us users choose if the button in the setting page should be on/off or pulse.
Hope this is possible.
If there isn’t enough memory, try to gain some by loosing some timer rules.
Thanks.
Best Regards, Diq
