Puesta en marcha kit vma501 placa vma100
Tengo el kit vma 501 con la placa vma100 . Agradecería donde dirigirme para poder instalar software,proyectos, esquema .Para poder ponerlo en funcionamiento.
Gracias.
Saludos.
Dear,
For programming the VMA100 (arduino UNO based controller board), you should use the ARDUINO IDE software.
This can be downloaded for free. Link: arduino.cc/en/Main/Software
When Upload a sketch (program code) make sure you should set the correct board in the software. Use the Arduino uno.
in the software: go to: Tools: Board: “Arduino/Genuino UNO”
Examples of basic sketches are implemented in the arduino software: “File => Examples”.
Link manual “VMA100”: velleman.eu/downloads/29/vm … _a4v01.pdf
Regards Velleman Support.
