Psu
Hi!
Just modified a Xbox 360 PSU to power the heated bed!
Also a pic of the SSR that i will use instead of the power board seen in the forums.
https://drive.google.com/file/d/0B32hc8fy_i4PLW5iQjlxOEJBYWM/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PanFqczJaSVJLYk0/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PaEU3RHBlQXRVcUU/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PMnZsOXQ1WVgxZHc/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PNFFkTnc5bDNPOUU/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4Pcll1WlJTNU03TU0/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PYk9IR2ZjclNYLWs/view?usp=sharing
some more pics…
https://drive.google.com/file/d/0B32hc8fy_i4PSWY4M3U0Y3QyeVU/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PVWdTd05VMXVaTGc/view?usp=sharing
https://drive.google.com/file/d/0B32hc8fy_i4PTWVYUGM0M1JFcjA/view?usp=sharing
The picture of your SSR shows an SSR for an AC load. Are you sure this is what you need?
If you use it to switch the DC power to the headed bed, it will not work.
Yeah, youre right. Mounted the wrong ssr. Will change to a DC load SSR. Thanks!
