Fer
June 28, 2015, 5:30am
1
Hello All
I am planning a heated bed, and i have a really nice 12V 600W PSU laying around.
xppower.com/EN/100469/SMC-SMD-Series
Would it be possible to run the main board on 12V ? (Can be adjusted to around 13.5-14V max)
Any drawbacks? Less heating in hotend?
Alternatively i could run 2 psu… But the SMC has all the juice i would ever need.
Fer
July 3, 2015, 5:55am
2
I have measured the max voltage from my SMC. It is 14,19Volt under load.
Is the 15Volt needed or would 14,3V be enough?
Regards Tommy Fer
raby
July 3, 2015, 6:34am
3
[quote=“Fer”]Is the 15Volt needed or would 14,3V be enough?[/quote]It should be enough. Don’t forget that you need a power expander between your bed and the controller board.
Fer
July 3, 2015, 6:53am
4
Thank you Raby
I allready have the power expander. I am currently running with 2 PSU, kind of stupid.
Regards Tommy Fer
Fer
July 13, 2015, 9:37pm
5
Just a feedback.
It runs perfectly on my 13,8Volt powersupply.
raby
July 14, 2015, 8:37am
6
[quote=“Fer”]Just a feedback.
It runs perfectly on my 13,8Volt powersupply.[/quote]
Fine! Did you power up the bed on the 12V Input?
Fer
July 14, 2015, 11:03am
7
[quote=“raby”][quote=“Fer”]Just a feedback.
Fine! Did you power up the bed on the 12V Input?[/quote]
Yes, and it work fine and fast when it is on it is using 18,2 A. So it is 13,8*18,2= 250W when it is heating. It heats up very fast.
