Programming K8090 with JAVA like K8055?
Can the K8090 programmed with JAVA like K8055 ?
FEZA
What source code do you use in Java for the K8055? It’s quite possible that it can be adapted to work for the K8090 as well. The K8090 also has a DLL with interfacing functions.
I use the interface from Mr. Wenzlaff´s TWUSB.dll.
Does K8090 have a similar interface?
FEZA
