I have soldered a K8090 realy board and it works with the manual buttons, and with the Demo application version 1.0.
I would like to use the functions of the .dll file, but apparently the function declarations for Excel VBA are not available. Therefore I am trying to program the K8090 with standard RS232 calls. But I have a few problems.
In K8090/VM8090 PROTOCOL MANUAL the baud rate is specified at 19200 baud. However when I connect with the Demo application my device manager (Windows 7) tells me that the baud rate is 9600. Which is correct?
The protocol manager gives a log of the traffic on the RS232 bus. In this traffic I do not recognize the protocol specified in the manual. It seems from the Demo application the the device receives a character 55 (hex), 2 bytes resp. " mask relays on" and “mask relays off”, and one bite that is in my case always “00”. This would be a command string of 4 bytes. However, the PROTOCOL MANUAL, specifies a completely different command structure of 7 bytes: STX, Command, Mask, Parameter 1, parameter 2, checksum, ETX.
With all these uncertainties the trial end error method of getting this to work is going to take a long time! Can anybody give some advice?
