Programming in VB 2005 ( K8061)
I use with a great satisfaction the K8061 modules which function perfectly.
My programming language is visual BASIC 6
I would like to make the transfer in the language visual BASIC 2005. I encounter certain problems with the management of lIB K8061.DLL
Would have you to it programming in VB 2005 of the demonstration examples or diagnosis
thank you in advance
LB
I had the response by another forum
it was enough to activate DLL USB
Thank you nevertheless
Nice that you found a solution!
What exactly do you mean with “activate DLL USB”?
By the way, which another forum did you get the answer from? It seems to be faster responses there than here. I posted a query here a couple of days ago but no response at all so far…
Only a handful of people here are software developers, hence why responses from velleman to these kinds of questions will always be slow… If you ask anything about the kit itself you’ll get an answer almost immediately :slight_smile:
I see :slight_smile:
Well, I guess, a slow response is better than no response… hope that you can help me.
These questions will probably increase by the the time since more and more people use C# and VB.NET.
Regards
Some additional informations:
For “the programmer”
I wanted to indicate that it was necessary to put in the repertory system32, not only the API k8061.dll but also API dependent K8061.dll
For the Velleman correspondent
I wanted to inform it simply that I had an answer to my question, and that it was not necessary of me to answer it.
Thank you for your contribution
