I like to program the PIC 18F2550 (28 pins) from Microchip using ICSP on the K8048.
- First of all, is this possible?
I found in the datasheet of 18F2550 that:
pin 1 is the vpp pin
pin 8 and 19 are the vss pins (is this gnd?)
pin 20 is the vdd pin
pin 26 is the enable pin (pgm)
pin 27 is the clock pin (pgc)
pin 28 is the data pin (pgd)
Which of these pins do I use and to what pin do they connect on the VM111?
There are only 5 pins on the VM111 while the 18F2550 provides 6 pins that have to do with ICSP; correct? -
Do I need to remove the jumpers?
JP5&6 are normally used to program on the board itself. -
Is there anything else I need to take into account?
Thank you in advance!
