Hi can I make a profile default in Repetier Cura.
It always change back to original profile.
I found that if I selected the new profile in the main Cura panel (towards the bottom, under filament, Extruder 1) it seemed to retain that as a sort of default whenever I restarted Repetier. Presumably if I change it there then the new selection will stay. I couldn’t see a ‘set as default’ option otherwise. I imagine the selected Print configuration is the same, but I only have 1
How do you mean? You can change stuff like default temp and extrusion rate in the Cura config. But it can be confusing as Repetier Host doesn’t re-load the changes you’ve made. Several times I’ve made changes, Repetier refuses to load them into memory and starts the next print with the old values.
What your showing is the configuration file. When you select your profile under “Print Settings/Print Configuration” it’s the one displayed when your start Repieter the next time.
How could I have missed that.
