Problems with retraction
Hi!
I’ve drawn a rim with 20 spokes. Outside diameter is 36.8 mm so it’s no small detail, but it is quite detailed because of the number of spokes.
All goes well until it comes to the spokes. Then it’s retraction causing problems for printing. due to retraction plastic stops in the nozzle. I use Simplify3D and in the process settings under the Extruder there are settings for Ooze Control and retraction, and I have unselected this. There are also Ooze behavior under the advanced settings, this is Also unselected. When Exporting the G-code file to a SD card and trying to print this file there is still Retraction active on the extruder causing problems. It looks like this setting is not transferred correctly when you export the file.
Is there any way to turn off the retraction directly in the K8400 under the settings and Motion for example?
