Problems with K8097 4Channel stepper driver
Hello community,
I recently built the K8097 Board. While testing i recognized that the motor on channel 2 and 4 were just shizzeling. I resoldered everything abd doublechecked the connections and it still doesnt work.
I tried the same motor on all 4 channels.
Sincerly
Julius
Did you try swapping the drivers from one channel to another?
Thanks i’ll try it :slight_smile:
Now its getting even worse. When i klick left in the software that comes with it, the motor on channel two turns randomly left or right, even with changed controllers. :frowning:
At first you said that the motors on channel 2 & 4 are just buzzing, correct?
The motors on channel 1 and 3, do they work correctly?
Are they the same motors?
Yes 1&3 works 2&4 Not/only sonetimes, all the same motors
So if the motors are identical and channels 1&3 work fine, then there must be an assembly problem with channels 2&4.
The drivers are not the problem, since you have swapped them.
Fixed it just resoldered the ic socets again :slight_smile:
