Hi.
I have trouble with filament that stucks in the nozzle.
It prints some layers, Then the filament stucks.
I have cleaned the hot end and even put in a new guide tube in the isolator.
I suspect that I have made some scratches inside the nozzle. Will that matter?
Is the nozzle blocked or the PEEK element?
I clean the nozzle with a needle from the pharmacies (the protection cap keeps it clean and safe for the user).
You have to change the filament settings in the slicer.
For the preheat function you can change those settings in the LCD menu.
The Load/Unload temperature cannot be changed from the LCD, only with a firmware update…
