hello,
i’m having some problems with the extruder. when i try to extrude some abs there is coming nithing out the nozzle and the extruder slips over the filament.
how can i solve this?
hello,
Have you tried the tips here?
http://manuals.velleman.eu/article/1-frequently-asked-questions-39.html
At first check your temperature setting.
Which temp did you set?
i’ve tried the tips and set the temperature to 250
but i ve just seen that the protective heatshrink from the thermistor is ripped
Does repetier show a reasonable temp?
If, not you probably shorted out your thermistor.
