HI, I have a problem, I can´t unload the filament, but the printer works fantastic, I can load the filament but always I have to disassemble the head to change the filament. It´s not possible to pull the filamnet out by hand. I don´t know what can I do.
Thanks!!
Check the screw that holds the lever on the extruder.
It maybe to tight.
If you can you might want to print one of these.
It makes loading easier and it you’re manually unloading it can help.
https://www.thingiverse.com/thing:2388938
The problem is solved, just you said the screw was to tight. Anyway I´m going to print the piece that you show me.
Thank you, very much!!
Glad to hear that helped
The load latch helps a lot.
Enjoy!
