Problem?
When I slice an object, I’m getting the following error report. >Slic3r- layer height can’t be greater than – nozzle-diameter. What am I doing wrong. Have even downloaded a new copy of Repetier program [ V1.0.6 ] but this does not help.
It sounds like the nozzle diameter is off.
It should be set for .5 in the slicer settings.
If you are new to the K8200 download this package.
It has been customized for the K8200 and a good starting place.
http://www.k8200.eu/downloads/files/downloads/setup_repetierhost_k8200_0_95f.zip
Thanks for your help
Glad to hear everything is good.
