Problem with VM154 Fan Timer
I bought this Item from Quasor in the UK. Installed it according to supplied documentation. It does not work. Fan comes on when Light activated and does not switch off regardless of DIP switch settings. Can anybody help?
posting.php?mode=post&f=21#
There has been a revision for this device.
Probably, you have a unit from a previous batch.
Check if D6 is mounted. If this is the case, you can return it for a free upgrade to:
Velleman Kit Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
