Problem with the x-Motor stepper
Dear Velleman Team,
My y-motor driver seems to function bad. When I manually control the y-stepper motor it makes a lot of noise and starts shaking. It doesn`t move at all, so i checked the voltage of the driver and that seems to be normal 0,427 Volt. So I changed the y-motor connector and the x-motor connector. Now the y-motor functions the right way and the x-motor doesn’t function any more. So the y-stepper motor is okay. Can you inform me about an appropriate action for my problem?
Thank you in advance for your answer.
Yours faithfully
M.Frei
Hi Clody,
Send an e-mail to support@velleman.be (put “TO JGE” in the subject) with your address and a short explanation of your problem. We will send you a new stepper driver asap.
Sincerely
Velleman Support Team
