Problem with Sending right gcode
At First everythink Works. Now i have the Problem that the Printer suddently Print at other positions…Same gcode as before.
I puted the v of the engines on 0,55 and than 0,65 - Same Problem!
I oiled the rails that they run easier - Same Problem!
Where is the Problem … At First ist Works correctly but suddenly the Problem cames.
I am using the configuration as it is shown on the Homepage and did not change them!!
What can i do??
i have tried a lot of things last weekend but nothing worked…
i think it is an software problem because when i move the plattform manuall over the pc it works…the gcode in the software shows the right way. i dont think its an mechanic problem because i checked everythink.
i also tried to install the repitier 0.90 software an downloaded the new settings but there was the same problem…
First make sure all the lights in your log window are on like the image below:
then when this error occurs copy everything in your log window and past it here.
I think due to vibration on of the endstops makes a connection. If so it will show up in the log.
all the lights are on and the codes ist
09:22:21.794 : OpenGL version:2.1.0 - Build 8.15.10.2202
09:22:21.795 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_ARB_vertex_array_object
09:22:21.795 : OpenGL renderer:Intel® HD Graphics
09:22:21.795 : Using fast VBOs for rendering is possible
09:23:01.038 : Starte Objektanalyse …
09:23:01.679 : Punkte:4587
09:23:01.679 : Kannten:13893
09:23:01.679 : Flächen:9262
09:23:01.679 : Hüllen:1
09:23:01.679 : Objekt ist mannigfaltig.
09:23:01.689 : Analyse beendet.
09:23:01.689 : Starte Objektanalyse …
09:23:01.770 : Punkte:4587
09:23:01.770 : Kannten:13893
09:23:01.770 : Flächen:9262
09:23:01.770 : Hüllen:1
09:23:01.770 : Objekt ist mannigfaltig.
09:23:01.772 : Analyse beendet.
09:23:13.151 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load “C:\Users\Rotzoll\AppData\Local\RepetierHost\slic3r.ini” --print-center 100,100 -o “C:\Users\Rotzoll\AppData\Local\RepetierHost\composition.gcode” “C:\Users\Rotzoll\AppData\Local\RepetierHost\composition.obj”
09:23:16.812 : => Processing triangulated mesh
09:23:21.900 : => Generating perimeters
09:23:39.461 : => Detecting solid surfaces
09:23:40.365 : => Preparing infill surfaces
09:23:40.366 : => Detect bridges
09:23:40.464 : => Generating horizontal shells
09:23:40.605 : => Combining infill
09:23:40.605 : => Infilling layers
09:24:00.184 : => Generating skirt
09:24:00.212 : => Exporting G-code to C:\Users\Rotzoll\AppData\Local\RepetierHost\composition.gcode
09:25:24.828 : Done. Process took 2 minutes and 8.065 seconds
09:25:24.828 : Filament required: 4867.6mm (34.4cm3)
09:25:44.077 : N1 M110 *2
09:25:44.078 : N2 M115 *4
09:25:44.087 : N3 T0 *25
09:25:44.087 : N4 M105 *3
09:25:44.134 : ok
09:25:44.134 : ok
09:25:44.134 : N5 M111 S6 *66
09:25:44.135 : N6 M80 *61
09:25:44.140 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup FIRMWARE_URL:http://www.K8200.eu - velleman.eu PROTOCOL_VERSION:1.0 MACHINE_TYPE:K8200 - 3D PRINTER EXTRUDER_COUNT:1
09:25:44.140 : ok
09:25:44.140 : echo:Active Extruder: 0
09:25:44.141 : ok
09:25:44.147 : N7 M80 *60
09:25:44.200 : ok T:22.0 /0.0 B:18.5 /0.0 @:0
09:25:44.200 : ok
09:25:44.200 : ok
09:25:44.200 : ok
09:25:44.200 : N8 M105 *15
09:25:44.201 : N9 M220 S100 *72
09:25:44.201 : N10 M221 S100 *113
09:25:44.217 : ok T:22.1 /0.0 B:18.5 /0.0 @:0
09:25:44.217 : ok
09:25:44.217 : ok
09:25:44.217 : N11 M111 S6 *119
09:25:44.231 : ok
09:25:45.360 : N12 G28 *0
09:25:47.185 : N13 M105 *53
09:25:50.240 : N14 M105 *50
09:25:53.302 : N15 M105 *51
09:25:53.970 : ok
09:25:53.993 : ok T:22.2 /0.0 B:18.4 /0.0 @:0
09:25:53.998 : ok T:22.2 /0.0 B:18.4 /0.0 @:0
09:25:54.001 : ok T:22.2 /0.0 B:18.4 /0.0 @:0
09:25:56.358 : N16 M105 *48
09:25:56.378 : ok T:22.2 /0.0 B:18.4 /0.0 @:0
09:25:59.412 : N17 M105 *49
09:25:59.422 : ok T:22.2 /0.0 B:18.4 /0.0 @:0
09:26:02.470 : N18 M105 *62
09:26:02.484 : ok T:22.1 /0.0 B:18.4 /0.0 @:0
09:26:05.282 : ok
09:26:05.283 : N19 G21 *2
09:26:05.319 : N20 M107 *55
09:26:05.323 : N21 M190 S50 *78
09:26:05.324 : N22 G28 *3
09:26:05.325 : N23 G90 *1
09:26:05.330 : ok
09:26:05.330 : N24 G21 *12
09:34:35.677 : ok
09:34:35.677 : N25 M105 *48
09:34:38.656 : ok
09:34:38.656 : ok
09:34:38.657 : ok
09:34:38.657 : N26 M105 *51
09:34:38.659 : N27 G92 E0 *82
09:34:38.660 : N28 M82 *3
09:34:38.684 : ok T:23.7 /0.0 B:50.2 /50.0 @:0
09:34:38.692 : N29 M109 S190 *123
09:34:38.700 : ok T:23.7 /0.0 B:50.2 /50.0 @:0
09:34:38.700 : ok
09:34:38.700 : ok
09:34:38.702 : N30 G1 E10 F400 *13
09:34:38.702 : N31 G90 *2
09:37:57.955 : ok
09:37:57.955 : ok
09:37:57.955 : N32 M105 *54
09:37:57.956 : N33 G92 E0 *87
09:37:57.956 : N34 M82 *14
09:37:57.971 : ok
09:37:57.991 : ok T:188.2 /190.0 B:50.0 /50.0 @:127
09:37:57.991 : ok
09:37:57.991 : ok
09:37:57.993 : N35 G1 E-3 F3900 *41
09:37:57.996 : N36 G92 E0 *82
09:37:57.997 : N37 G1 Z0.3 F12000 *62
09:37:58.003 : ok
09:37:58.003 : ok
09:37:58.003 : ok
09:37:58.003 : N38 M105 *60
09:37:58.004 : N39 G1 X62.76 Y40.57 *48
09:37:58.004 : N40 G1 E3.1 F3900 *25
09:37:58.029 : ok T:188.2 /190.0 B:50.0 /50.0 @:127
09:37:58.029 : ok
09:37:58.029 : ok
09:37:58.030 : Drucke Layer 1 von 200
09:37:58.033 : N41 G1 X63.05 Y40.18 E3.10832 F1530 *16
09:37:58.050 : ok
09:37:58.051 : N42 G1 X63.7 Y39.43 E3.1253 *125
09:37:58.066 : ok
09:37:58.067 : N43 G1 X64.46 Y38.78 E3.14241 *112
09:37:58.082 : ok
09:37:58.083 : N44 G1 X64.84 Y38.5 E3.15048 *73
09:37:58.098 : ok
09:37:58.099 : N45 G1 X65.48 Y38.08 E3.16358 *117
09:37:58.114 : ok
09:37:58.115 : N46 G1 X66.16 Y37.74 E3.17659 *127
09:37:58.130 : ok
09:37:58.131 : N47 G1 X66.6 Y37.55 E3.18479 *67
09:37:58.146 : ok
09:37:58.147 : N48 G1 X67.49 Y37.24 E3.20091 *121
09:37:58.163 : ok
09:37:58.163 : N49 G1 X68.42 Y37.05 E3.21715 *117
09:37:58.178 : ok
09:37:58.179 : N50 G1 X68.89 Y36.99 E3.22526 *127
09:37:58.194 : ok
09:37:58.195 : N51 G1 X69.74 Y36.94 E3.23983 *114
09:37:58.210 : ok
09:37:58.211 : N52 G1 X130.25 Y36.94 E4.27512 *79
09:37:59.476 : ok
09:37:59.476 : N53 G1 X131.1 Y36.99 E4.28968 *122
09:37:59.572 : ok
09:37:59.573 : N54 G1 X131.57 Y37.05 E4.29779 *69
09:37:59.652 : ok
09:37:59.653 : N55 G1 X132.5 Y37.24 E4.31403 *116
09:38:00.213 : ok
09:38:00.213 : N56 G1 X133.39 Y37.55 E4.33016 *77
09:38:00.309 : echo:endstops hit: Y:40.51
09:38:00.309 : ok
09:38:00.309 : echo:endstops hit: Y:40.50
09:38:00.309 : N57 G1 X133.83 Y37.74 E4.33836 *68
09:38:00.325 : ok
09:38:00.325 : N58 G1 X134.51 Y38.08 E4.35136 *72
09:38:00.341 : ok
09:38:00.341 : N59 G1 X135.15 Y38.5 E4.36446 *116
09:38:00.357 : ok
09:38:00.357 : N60 G1 X135.53 Y38.78 E4.37254 *66
09:38:00.372 : ok
09:38:00.373 : N61 G1 X136.3 Y39.44 E4.38989 *127
09:38:00.389 : ok
09:38:00.390 : N62 G1 X136.96 Y40.21 E4.40724 *75
09:38:00.405 : ok
09:38:00.406 : N63 G1 X137.24 Y40.59 E4.41532 *73
09:38:00.420 : ok
09:38:00.422 : N64 G1 X137.66 Y41.23 E4.42841 *78
09:38:00.437 : ok
09:38:00.439 : N65 G1 X138 Y41.91 E4.44142 *107
09:38:00.452 : ok
09:38:00.453 : N66 G1 X138.19 Y42.35 E4.44962 *73
09:38:00.468 : ok
09:38:00.469 : N67 G1 X138.51 Y43.25 E4.46596 *65
09:38:00.484 : ok
09:38:00.485 : N68 G1 X138.69 Y44.18 E4.48217 *76
09:38:01.059 : N69 M105 *56
09:38:02.695 : ok
09:38:02.696 : N70 G1 X138.75 Y44.66 E4.49045 *69
09:38:02.747 : ok T:188.5 /190.0 B:49.9 /50.0 @:127
09:38:02.747 : ok
09:38:02.749 : N71 G1 X138.8 Y45.5 E4.50484 *75
09:38:02.759 : ok
09:38:02.760 : N72 G1 X138.8 Y154.5 E6.36977 *122
09:38:02.775 : ok
09:38:02.776 : N73 G1 X138.75 Y155.35 E6.38434 *119
09:38:02.807 : ok
09:38:02.808 : N74 G1 X138.69 Y155.82 E6.39244 *113
09:38:02.839 : ok
09:38:02.840 : N75 G1 X138.51 Y156.71 E6.40798 *126
09:38:02.871 : ok
09:38:02.872 : N76 G1 X138.22 Y157.57 E6.42351 *127
09:38:02.887 : ok
09:38:02.888 : N77 G1 X138.04 Y158 E6.43148 *82
09:38:02.919 : ok
09:38:02.920 : N78 G1 X137.68 Y158.73 E6.44541 *120
09:38:02.951 : ok
09:38:02.953 : N79 G1 X137.23 Y159.42 E6.4595 *72
09:38:02.999 : ok
09:38:03.000 : N80 G1 X136.94 Y159.81 E6.46782 *126
09:38:03.015 : ok
09:38:03.016 : N81 G1 X136.3 Y160.55 E6.48456 *70
09:38:03.047 : ok
09:38:03.048 : N82 G1 X135.56 Y161.19 E6.5013 *67
09:38:03.063 : ok
09:38:03.064 : N83 G1 X135.17 Y161.48 E6.50961 *127
09:38:03.095 : ok
09:38:03.096 : N84 G1 X134.48 Y161.93 E6.52371 *124
09:38:03.127 : ok
09:38:03.128 : N85 G1 X133.75 Y162.29 E6.53763 *112
09:38:03.159 : ok
09:38:03.160 : N86 G1 X133.32 Y162.47 E6.54561 *127
09:38:03.175 : ok
09:38:03.176 : N87 G1 X132.45 Y162.77 E6.56135 *123
09:38:03.223 : ok
09:38:03.224 : N88 G1 X131.56 Y162.94 E6.57686 *118
09:38:04.117 : N89 M105 *54
09:38:07.484 : ok
09:38:07.484 : N90 M105 *62
09:38:07.485 : N91 G1 X131.08 Y163 E6.58513 *87
09:38:07.557 : ok T:195.1 /190.0 B:50.0 /50.0 @:0
09:38:07.578 : ok T:195.1 /190.0 B:50.0 /50.0 @:0
09:38:07.578 : ok
09:38:07.579 : N92 G1 X130.24 Y163.05 E6.59953 *121
09:38:07.585 : ok
09:38:07.585 : N93 G1 X69.74 Y163.05 E7.63465 *64
09:38:07.601 : ok
09:38:07.601 : N94 G1 X68.89 Y163 E7.64922 *102
09:38:07.617 : ok
09:38:07.617 : N95 G1 X68.42 Y162.94 E7.65732 *76
09:38:07.633 : ok
09:38:07.633 : N96 G1 X67.49 Y162.75 E7.67356 *64
09:38:07.665 : ok
09:38:07.665 : N97 G1 X66.6 Y162.44 E7.68969 *112
09:38:07.697 : ok
09:38:07.698 : N98 G1 X66.16 Y162.25 E7.69789 *72
09:38:07.713 : ok
09:38:07.714 : N99 G1 X65.48 Y161.91 E7.71089 *67
09:38:07.761 : ok
09:38:07.762 : N100 G1 X64.84 Y161.49 E7.72399 *119
09:38:07.793 : ok
09:38:07.794 : N101 G1 X64.46 Y161.21 E7.73207 *113
09:38:07.809 : ok
09:38:07.810 : N102 G1 X63.69 Y160.55 E7.74942 *119
09:38:07.841 : ok
09:38:07.842 : N103 G1 X63.03 Y159.78 E7.76677 *116
09:38:07.873 : ok
09:38:07.874 : N104 G1 X62.75 Y159.4 E7.77485 *70
09:38:07.889 : ok
09:38:07.890 : N105 G1 X62.33 Y158.76 E7.78794 *125
09:38:07.937 : ok
09:38:07.938 : N106 G1 X61.99 Y158.08 E7.80095 *117
09:38:07.969 : ok
09:38:07.972 : N107 G1 X61.8 Y157.64 E7.80915 *72
09:38:07.985 : ok
09:38:07.986 : N108 G1 X61.49 Y156.75 E7.82528 *115
09:38:08.017 : ok
09:38:08.018 : N109 G1 X61.3 Y155.82 E7.84152 *72
09:38:10.233 : N110 M105 *7
09:38:10.387 : ok
09:38:10.388 : N111 G1 X61.24 Y155.35 E7.84962 *115
09:38:10.442 : ok T:195.9 /190.0 B:50.0 /50.0 @:0
09:38:10.442 : ok
09:38:10.446 : N112 G1 X61.19 Y154.5 E7.86419 *79
09:38:10.452 : ok
09:38:10.452 : N113 G1 X61.19 Y45.5 E9.72912 *124
09:38:10.483 : ok
09:38:10.484 : N114 G1 X61.24 Y44.66 E9.74351 *74
09:38:10.515 : ok
09:38:10.516 : N115 G1 X61.3 Y44.18 E9.75179 *126
09:38:10.531 : ok
09:38:10.532 : N116 G1 X61.47 Y43.29 E9.76729 *72
09:38:10.563 : ok
09:38:10.564 : N117 G1 X61.77 Y42.42 E9.78304 *67
09:38:10.595 : ok
09:38:10.596 : N118 G1 X61.95 Y41.99 E9.79101 *67
09:38:10.611 : ok
09:38:10.612 : N119 G1 X62.31 Y41.26 E9.80494 *68
09:38:10.660 : ok
09:38:10.660 : N120 G1 X62.73 Y40.616 E9.81809 *117
09:38:10.692 : ok
09:38:10.692 : N121 G1 X63.05 Y40.79 F12000 *84
09:38:10.708 : ok
09:38:10.708 : N122 G1 X63.34 Y40.4 E9.82641 F1530 *16
09:38:10.740 : ok
09:38:10.740 : N123 G1 X63.96 Y39.69 E9.84254 *75
09:38:10.772 : ok
09:38:10.772 : N124 G1 X64.67 Y39.07 E9.85866 *71
09:38:10.788 : ok
09:38:10.788 : N125 G1 X65.05 Y38.79 E9.86674 *69
09:38:10.836 : ok
09:38:10.836 : N126 G1 X65.66 Y38.4 E9.87913 *118
09:38:10.868 : ok
09:38:10.868 : N127 G1 X66.31 Y38.08 E9.89152 *73
09:38:10.884 : ok
09:38:10.885 : N128 G1 X66.75 Y37.89 E9.89972 *74
09:38:10.916 : ok
09:38:10.916 : N129 G1 X67.59 Y37.59 E9.91498 *73
09:38:13.290 : N130 M105 *5
09:38:15.193 : ok
09:38:15.193 : N131 G1 X68.46 Y37.41 E9.93018 *70
09:38:15.245 : ok T:192.8 /190.0 B:50.0 /50.0 @:126
09:38:15.245 : ok
09:38:15.249 : N132 G1 X68.93 Y37.35 E9.93829 *68
09:38:15.257 : ok
09:38:15.257 : N133 G1 X69.74 Y37.3 E9.95217 *121
09:38:15.288 : ok
09:38:15.289 : N134 G1 X130.25 Y37.3 E10.98746 *115
09:38:15.320 : ok
09:38:15.321 : N135 G1 X131.06 Y37.35 E11.00135 *69
09:38:15.336 : ok
09:38:15.337 : N136 G1 X131.53 Y37.41 E11.00946 *73
09:38:15.368 : ok
09:38:15.369 : N137 G1 X132.4 Y37.59 E11.02466 *125
09:38:15.400 : ok
09:38:15.402 : N138 G1 X133.24 Y37.89 E11.03992 *75
09:38:15.416 : ok
09:38:15.417 : N139 G1 X133.68 Y38.08 E11.04812 *74
09:38:15.448 : ok
09:38:15.449 : N140 G1 X134.33 Y38.4 E11.06051 *124
09:38:15.480 : ok
09:38:15.481 : N141 G1 X134.94 Y38.79 E11.0729 *116
09:38:15.513 : ok
09:38:15.513 : N142 G1 X135.32 Y39.07 E11.08098 *71
09:38:15.545 : ok
09:38:15.545 : N143 G1 X136.04 Y39.7 E11.09735 *113
09:38:15.561 : ok
09:38:15.561 : N144 G1 X136.67 Y40.42 E11.11371 *65
09:38:15.593 : ok
09:38:15.593 : N145 G1 X136.95 Y40.8 E11.12179 *122
09:38:15.609 : ok
09:38:15.609 : N146 G1 X137.34 Y41.41 E11.13418 *76
09:38:15.640 : ok
09:38:15.642 : N147 G1 X137.66 Y42.06 E11.14657 *68
09:38:15.689 : ok
09:38:15.689 : N148 G1 X137.85 Y42.5 E11.15477 *116
09:38:15.705 : ok
09:38:15.706 : N149 G1 X138.15 Y43.35 E11.1702 *117
09:38:15.737 : ok
09:38:15.740 : N150 G1 X138.33 Y44.23 E11.18556 *66
09:38:16.346 : N151 M105 *2
09:38:18.107 : ok
09:38:18.108 : N152 G1 X138.39 Y44.71 E11.19384 *69
09:38:18.159 : ok T:189.5 /190.0 B:49.8 /50.0 @:127
09:38:18.159 : ok
09:38:18.160 : N153 G1 X138.44 Y45.5 E11.20738 *117
09:38:18.171 : ok
09:38:18.174 : N154 G1 X138.44 Y154.5 E13.07231 *72
09:38:18.187 : ok
09:38:18.189 : N155 G1 X138.39 Y155.31 E13.08619 *116
09:38:18.219 : ok
09:38:18.220 : N156 G1 X138.33 Y155.78 E13.0943 *72
09:38:18.251 : ok
09:38:18.252 : N157 G1 X138.16 Y156.62 E13.10896 *126
09:38:18.267 : ok
09:38:18.268 : N158 G1 X137.88 Y157.43 E13.12363 *120
09:38:18.299 : ok
09:38:18.300 : N159 G1 X137.7 Y157.86 E13.1316 *119
09:38:18.315 : ok
09:38:18.316 : N160 G1 X137.36 Y158.55 E13.14476 *123
09:38:18.363 : ok
09:38:18.364 : N161 G1 X136.94 Y159.2 E13.158 *76
09:38:18.395 : ok
09:38:18.396 : N162 G1 X136.65 Y159.59 E13.16632 *115
09:38:18.411 : ok
09:38:18.412 : N163 G1 X136.04 Y160.29 E13.1822 *65
09:38:18.443 : ok
09:38:18.444 : N164 G1 X135.34 Y160.9 E13.19809 *68
09:38:18.475 : ok
09:38:18.476 : N165 G1 X134.95 Y161.19 E13.2064 *70
09:38:18.491 : ok
09:38:18.492 : N166 G1 X134.3 Y161.61 E13.21965 *76
09:38:18.523 : ok
09:38:18.524 : N167 G1 X133.61 Y161.95 E13.23281 *118
09:38:18.555 : ok
09:38:18.556 : N168 G1 X133.18 Y162.13 E13.24078 *121
09:38:18.587 : ok
09:38:18.589 : N169 G1 X132.36 Y162.41 E13.25561 *126
09:38:18.603 : ok
09:38:18.604 : N170 G1 X131.51 Y162.58 E13.27044 *124
09:38:19.408 : N171 M105 *0
09:38:22.880 : ok
09:38:22.880 : N172 M105 *3
09:38:22.947 : ok T:190.3 /190.0 B:49.7 /50.0 @:5
09:38:22.949 : N173 G1 X131.03 Y162.64 E13.27871 *121
09:38:22.966 : ok T:190.3 /190.0 B:49.7 /50.0 @:5
09:38:22.968 : ok
09:38:22.970 : N174 G1 X130.24 Y162.69 E13.29226 *113
09:38:22.976 : ok
09:38:22.976 : N175 G1 X69.74 Y162.69 E14.32738 *79
09:38:22.992 : ok
09:38:22.992 : N176 G1 X68.93 Y162.64 E14.34126 *70
09:38:23.008 : ok
09:38:23.008 : N177 G1 X68.46 Y162.58 E14.34937 *72
09:38:23.024 : ok
09:38:23.025 : N178 G1 X67.59 Y162.4 E14.36457 *118
09:38:23.056 : ok
09:38:23.057 : N179 G1 X66.75 Y162.1 E14.37983 *120
09:38:23.088 : ok
09:38:23.088 : N180 G1 X66.31 Y161.91 E14.38803 *66
09:38:23.104 : ok
09:38:23.105 : N181 G1 X65.66 Y161.59 E14.40042 *68
09:38:23.136 : ok
09:38:23.137 : N182 G1 X65.05 Y161.2 E14.41281 *112
09:38:23.168 : ok
09:38:23.169 : N183 G1 X64.67 Y160.92 E14.42089 *69
09:38:23.200 : ok
09:38:23.201 : N184 G1 X63.95 Y160.29 E14.43726 *75
09:38:23.216 : ok
09:38:23.217 : N185 G1 X63.32 Y159.57 E14.45363 *71
09:38:23.248 : ok
09:38:23.249 : N186 G1 X63.04 Y159.19 E14.4617 *120
09:38:23.280 : ok
09:38:23.281 : N187 G1 X62.65 Y158.58 E14.47409 *65
09:38:23.312 : ok
09:38:23.313 : N188 G1 X62.33 Y157.93 E14.48649 *76
09:38:23.344 : ok
09:38:23.345 : N189 G1 X62.14 Y157.49 E14.49469 *78
09:38:23.360 : ok
09:38:23.361 : N190 G1 X61.84 Y156.65 E14.50995 *69
09:38:23.392 : ok
09:38:23.393 : N191 G1 X61.66 Y155.78 E14.52515 *65
09:38:25.519 : N192 M105 *13
09:38:25.762 : ok
09:38:25.763 : N193 G1 X61.6 Y155.31 E14.53325 *124
09:38:25.815 : ok T:191.6 /190.0 B:49.7 /50.0 @:0
09:38:25.815 : ok
09:38:25.818 : N194 G1 X61.55 Y154.5 E14.54714 *122
09:38:25.826 : ok
09:38:25.827 : N195 G1 X61.55 Y45.5 E16.41206 *74
09:38:25.842 : ok
09:38:25.843 : N196 G1 X61.6 Y44.71 E16.42561 *72
09:38:25.891 : ok
09:38:25.891 : N197 G1 X61.66 Y44.23 E16.43388 *120
09:38:25.906 : ok
09:38:25.907 : N198 G1 X61.83 Y43.38 E16.44871 *123
09:38:25.938 : ok
09:38:25.939 : N199 G1 X62.11 Y42.56 E16.46354 *117
09:38:25.954 : ok
09:38:25.955 : N200 G1 X62.29 Y42.13 E16.47151 *122
09:38:25.970 : ok
09:38:25.971 : N201 G1 X62.63 Y41.44 E16.48467 *123
09:38:26.018 : ok
09:38:26.019 : N202 G1 X63.02 Y40.836 E16.49697 *78
09:38:26.050 : ok
09:38:26.051 : N203 G1 E13.49697 F3900 *25
09:38:26.052 : N204 G92 E0 *97
09:38:26.066 : ok
09:38:26.067 : N205 G1 X117.891 Y54.376 F12000 *111
09:38:26.098 : ok
09:38:26.098 : ok
09:38:26.100 : N206 G1 E3.1 F3900 *41
09:38:26.130 : ok
09:38:26.132 : N207 G1 X118.084 Y53.912 E3.10859 F1530 *24
09:38:26.146 : ok
09:38:26.148 : N208 G1 X118.389 Y53.513 E3.11719 *127
09:38:26.178 : ok
09:38:26.179 : N209 G1 X118.788 Y53.207 E3.12578 *127
09:38:26.575 : ok
09:38:26.577 : N210 G1 X119.252 Y53.015 E3.13438 *113
09:38:26.595 : ok
09:38:26.596 : N211 G1 X119.69 Y52.957 E3.14193 *71
09:38:26.611 : ok
09:38:26.612 : N212 G1 X120.31 Y52.957 E3.15254 *74
09:38:28.576 : N213 M105 *7
09:38:30.535 : ok
09:38:30.536 : N214 G1 X120.748 Y53.015 E3.1601 *74
09:38:30.587 : ok T:193.7 /190.0 B:49.8 /50.0 @:0
09:38:30.589 : ok
09:38:30.591 : N215 G1 X121.212 Y53.207 E3.1687 *79
09:38:30.599 : ok
09:38:30.600 : N216 G1 X121.611 Y53.513 E3.17729 *123
09:38:30.631 : ok
09:38:30.632 : N217 G1 X121.916 Y53.912 E3.18588 *121
09:38:30.663 : ok
09:38:30.664 : N218 G1 X122.109 Y54.376 E3.19448 *112
09:38:30.679 : ok
09:38:30.680 : N219 G1 X122.166 Y54.814 E3.20203 *116
09:38:30.711 : ok
09:38:30.712 : N220 G1 X122.166 Y89.06 E3.78797 *64
09:38:30.743 : ok
09:38:30.744 : N221 G1 X122.109 Y89.498 E3.79553 *112
09:38:30.839 : ok
09:38:30.840 : N222 G1 X121.916 Y89.962 E3.80412 *124
09:38:31.304 : ok
09:38:31.305 : N223 G1 X121.611 Y90.361 E3.81272 *117
09:38:31.400 : echo:endstops hit: Y:57.90
09:38:31.400 : ok
09:38:31.400 : echo:endstops hit: Y:57.88
09:38:31.401 : N224 G1 X121.212 Y90.666 E3.82131 *112
09:38:31.416 : ok
09:38:31.417 : N225 G1 X120.748 Y90.859 E3.8299 *75
09:38:31.432 : ok
09:38:31.433 : N226 G1 X120.31 Y90.916 E3.83746 *79
09:38:31.451 : ok
09:38:31.452 : N227 G1 X119.69 Y90.916 E3.84807 *68
09:38:31.464 : ok
09:38:31.465 : N228 G1 X119.252 Y90.859 E3.85563 *117
09:38:31.480 : ok
09:38:31.481 : N229 G1 X118.788 Y90.666 E3.86422 *114
09:38:31.496 : ok
09:38:31.497 : N230 G1 X118.389 Y90.361 E3.87282 *112
09:38:31.512 : ok
09:38:31.513 : N231 G1 X118.084 Y89.962 E3.88141 *125
09:38:31.528 : ok
09:38:31.529 : N232 G1 X117.891 Y89.498 E3.89001 *113
09:38:31.544 : ok
09:38:31.545 : N233 G1 X117.834 Y89.06 E3.89756 *73
09:38:31.560 : ok
09:38:31.561 : N234 G1 X117.834 Y54.814 E4.4835 *77
09:38:31.576 : ok
09:38:31.577 : N235 G1 X117.884 Y54.43 E4.49012 *73
09:38:31.592 : ok
09:38:31.593 : N236 G1 X118.248 Y54.471 F12000 *110
09:38:31.638 : N237 M105 *1
09:38:32.891 : ok
09:38:32.892 : N238 G1 X118.404 Y54.096 E4.49706 F1530 *20
09:38:32.928 : ok T:192.8 /190.0 B:49.8 /50.0 @:0
09:38:32.928 : ok
09:38:32.931 : N239 G1 X118.651 Y53.774 E4.504 *119
09:38:32.939 : ok
09:38:32.939 : N240 G1 X118.973 Y53.527 E4.51095 *123
09:38:32.955 : ok
09:38:32.955 : N241 G1 X119.348 Y53.372 E4.51789 *117
09:38:32.971 : ok
09:38:32.971 : N242 G1 X119.714 Y53.324 E4.52421 *122
09:38:32.987 : ok
09:38:32.987 : N243 G1 X120.286 Y53.324 E4.534 *125
09:38:33.003 : ok
09:38:33.003 : N244 G1 X120.652 Y53.372 E4.54032 *118
09:38:33.019 : echo:endstops hit: Y:95.81
09:38:33.019 : ok
09:38:33.019 : N245 G1 X121.027 Y53.527 E4.54726 *118
09:38:33.035 : echo:endstops hit: Y:95.77
09:38:33.035 : ok
09:38:33.035 : N246 G1 X121.349 Y53.774 E4.5542 *78
09:38:33.051 : ok
09:38:33.051 : echo:endstops hit: Y:95.75
09:38:33.051 : N247 G1 X121.596 Y54.096 E4.56115 *119
09:38:33.067 : ok
09:38:33.067 : N248 G1 X121.751 Y54.471 E4.56809 *120
09:38:33.083 : ok
09:38:33.083 : N249 G1 X121.8 Y54.838 E4.57441 *114
09:38:33.099 : ok
09:38:33.099 : N250 G1 X121.8 Y89.036 E5.15953 *117
09:38:33.115 : ok
09:38:33.116 : N251 G1 X121.752 Y89.402 E5.16585 *123
09:38:33.131 : ok
09:38:33.131 : N252 G1 X121.596 Y89.777 E5.17279 *118
09:38:33.147 : ok
09:38:33.147 : N253 G1 X121.349 Y90.099 E5.17973 *125
09:38:33.163 : ok
09:38:33.163 : N254 G1 X121.027 Y90.346 E5.18668 *122
09:38:33.179 : ok
09:38:33.179 : N255 G1 X120.652 Y90.502 E5.19362 *118
09:38:33.195 : ok
09:38:33.195 : N256 G1 X120.286 Y90.55 E5.19994 *76
09:38:33.211 : ok
09:38:33.211 : N257 G1 X119.714 Y90.55 E5.20973 *74
09:38:33.227 : ok
09:38:33.227 : N258 G1 X119.348 Y90.502 E5.21605 *112
09:38:33.243 : ok
09:38:33.243 : N259 G1 X118.973 Y90.346 E5.22299 *118
09:38:33.259 : ok
09:38:33.259 : N260 G1 X118.651 Y90.099 E5.22993 *115
09:38:33.275 : ok
09:38:33.275 : N261 G1 X118.404 Y89.777 E5.23688 *123
09:38:33.291 : ok
09:38:33.292 : N262 G1 X118.248 Y89.402 E5.24382 *127
09:38:33.307 : ok
09:38:33.307 : N263 G1 X118.2 Y89.036 E5.25014 *124
09:38:33.323 : ok
09:38:33.323 : N264 G1 X118.2 Y54.838 E5.83526 *117
09:38:33.339 : ok
09:38:33.339 : N265 G1 X118.241 Y54.526 E5.84064 *119
09:38:33.355 : ok
09:38:33.355 : N266 G1 X118.606 Y54.567 F12000 *99
09:38:34.524 : ok
09:38:34.525 : N267 G1 X118.724 Y54.281 E5.84593 F1453.5 *10
09:38:34.540 : ok
09:38:34.541 : N268 G1 X118.912 Y54.036 E5.85122 *113
09:38:34.556 : ok
09:38:34.558 : N269 G1 X119.158 Y53.848 E5.85651 *114
09:38:34.572 : ok
09:38:34.573 : N270 G1 X119.443 Y53.729 E5.8618 *69
09:38:34.588 : ok
09:38:34.589 : N271 G1 X119.738 Y53.69 E5.86689 *70
09:38:34.604 : ok
09:38:34.605 : N272 G1 X120.262 Y53.69 E5.87586 *72
09:38:34.636 : ok
09:38:34.637 : N273 G1 X120.557 Y53.729 E5.88094 *114
09:38:34.652 : echo:endstops hit: Y:132.95
09:38:34.652 : ok
09:38:34.652 : echo:endstops hit: Y:132.90
09:38:34.653 : N274 G1 X120.842 Y53.848 E5.88623 *126
09:38:34.668 : ok
09:38:34.668 : echo:endstops hit: Y:132.92
09:38:34.669 : N275 G1 X121.088 Y54.036 E5.89152 *118
09:38:34.684 : echo:endstops hit: Y:132.89
09:38:34.684 : ok
09:38:34.684 : echo:endstops hit: Y:132.87
09:38:34.685 : N276 G1 X121.276 Y54.281 E5.89682 *114
09:38:34.694 : N277 M105 *5
09:38:34.700 : ok
09:38:34.703 : N278 G1 X121.394 Y54.567 E5.90211 *120
09:38:34.720 : ok T:192.1 /190.0 B:49.9 /50.0 @:19
09:38:34.720 : ok
09:38:34.722 : N279 G1 X121.433 Y54.862 E5.90719 *118
09:38:34.732 : ok
09:38:34.733 : N280 G1 X121.433 Y89.012 E6.49149 *123
09:38:34.748 : ok
09:38:34.749 : N281 G1 X121.394 Y89.307 E6.49657 *127
09:38:34.764 : ok
09:38:34.764 : N282 G1 X121.276 Y89.592 E6.50186 *120
09:38:34.780 : ok
09:38:34.781 : N283 G1 X121.088 Y89.838 E6.50715 *123
09:38:34.796 : ok
09:38:34.797 : N284 G1 X120.842 Y90.026 E6.51245 *125
09:38:34.812 : ok
09:38:34.813 : N285 G1 X120.557 Y90.144 E6.51774 *119
09:38:34.828 : ok
09:38:34.829 : N286 G1 X120.262 Y90.183 E6.52282 *113
09:38:34.844 : ok
09:38:34.845 : N287 G1 X119.738 Y90.183 E6.53179 *118
09:38:34.860 : ok
09:38:34.861 : N288 G1 X119.443 Y90.144 E6.53687 *123
09:38:34.876 : ok
09:38:34.877 : N289 G1 X119.158 Y90.026 E6.54216 *123
09:38:34.892 : ok
09:38:34.893 : N290 G1 X118.912 Y89.838 E6.54746 *123
09:38:34.908 : ok
09:38:34.909 : N291 G1 X118.724 Y89.592 E6.55275 *120
09:38:34.924 : ok
09:38:34.925 : N292 G1 X118.606 Y89.307 E6.55804 *124
09:38:34.940 : ok
09:38:34.943 : N293 G1 X118.567 Y89.012 E6.56313 *112
09:38:34.956 : ok
09:38:34.957 : N294 G1 X118.567 Y54.862 E7.14742 *127
09:38:34.972 : ok
09:38:34.974 : N295 G1 X118.598 Y54.621 E7.15156 *117
09:38:34.988 : ok
09:38:34.989 : N296 G1 X118.908 Y54.5 F12000 *108
09:38:36.221 : ok
09:38:36.222 : N297 G1 X117.155 Y54.732 *52
09:38:36.237 : ok
09:38:36.238 : N298 G1 X117.166 Y89.06 E7.7389 F1530 *19
09:38:36.254 : ok
09:38:36.254 : N299 G1 X117.109 Y89.498 E7.74645 *120
09:38:36.269 : ok
09:38:36.271 : N300 G1 X116.916 Y89.962 E7.75505 *112
09:38:36.286 : ok
09:38:36.286 : N301 G1 X116.611 Y90.361 E7.76364 *122
09:38:36.301 : ok
09:38:36.302 : N302 G1 X116.212 Y90.666 E7.77224 *120
09:38:36.318 : ok
09:38:36.318 : N303 G1 X115.748 Y90.859 E7.78083 *114
09:38:36.333 : ok
09:38:36.334 : N304 G1 X115.31 Y90.916 E7.78839 *79
09:38:36.349 : ok
09:38:36.350 : N305 G1 X114.69 Y90.916 E7.799 *72
09:38:36.366 : ok
09:38:36.367 : N306 G1 X114.252 Y90.859 E7.80656 *113
09:38:36.381 : ok
09:38:36.382 : N307 G1 X113.788 Y90.666 E7.81515 *114
09:38:36.397 : ok
09:38:36.398 : N308 G1 X113.389 Y90.361 E7.82374 *120
09:38:36.413 : ok
09:38:36.414 : N309 G1 X113.084 Y89.962 E7.83234 *114
09:38:36.429 : ok
09:38:36.430 : N310 G1 X112.891 Y89.498 E7.84093 *119
09:38:37.750 : N311 M105 *4
09:38:37.823 : ok
09:38:37.824 : N312 G1 X112.834 Y89.06 E7.84849 *70
09:38:37.860 : ok T:190.5 /190.0 B:50.1 /50.0 @:127
09:38:37.860 : ok
09:38:37.864 : N313 G1 X112.834 Y54.814 E8.43443 *126
09:38:37.871 : ok
09:38:37.874 : N314 G1 X112.891 Y54.376 E8.44198 *125
09:38:37.919 : ok
09:38:37.921 : N315 G1 X113.084 Y53.912 E8.45058 *114
09:38:39.280 : ok
09:38:39.281 : N316 G1 X113.389 Y53.513 E8.45917 *112
09:38:39.296 : ok
09:38:39.297 : N317 G1 X113.788 Y53.207 E8.46776 *124
09:38:39.312 : ok
09:38:39.313 : N318 G1 X114.252 Y53.015 E8.47636 *115
09:38:39.328 : ok
09:38:39.329 : N319 G1 X114.69 Y52.957 E8.48392 *66
09:38:39.344 : ok
09:38:39.345 : N320 G1 X115.31 Y52.957 E8.49453 *79
09:38:39.376 : ok
09:38:39.377 : N321 G1 X115.748 Y53.015 E8.50208 *121
09:38:39.392 : ok
09:38:39.393 : N322 G1 X116.212 Y53.207 E8.51068 *119
09:38:39.408 : ok
09:38:39.409 : N323 G1 X116.611 Y53.513 E8.51927 *113
09:38:39.424 : ok
09:38:39.425 : N324 G1 X116.916 Y53.912 E8.52787 *116
09:38:39.440 : ok
09:38:39.441 : N325 G1 X117.109 Y54.376 E8.53646 *112
09:38:39.472 : ok
09:38:39.473 : N326 G1 X117.148 Y54.677 E8.54167 *113
09:38:39.488 : ok
09:38:39.489 : N327 G1 X116.792 Y54.78 F12000 *94
09:38:39.504 : ok
09:38:39.505 : N328 G1 X116.8 Y89.036 E9.12777 F1530 *29
09:38:39.520 : ok
09:38:39.521 : N329 G1 X116.752 Y89.402 E9.13409 *125
09:38:40.812 : N330 M105 *7
09:38:40.866 : ok
09:38:40.866 : N331 G1 X116.596 Y89.777 E9.14104 *112
09:38:40.903 : ok T:187.2 /190.0 B:50.2 /50.0 @:127
09:38:40.903 : ok
09:38:40.907 : N332 G1 X116.349 Y90.099 E9.14798 *123
09:38:40.914 : ok
09:38:40.914 : N333 G1 X116.027 Y90.346 E9.15492 *120
09:38:40.930 : ok
09:38:40.930 : N334 G1 X115.652 Y90.502 E9.16186 *125
09:38:40.946 : ok
09:38:40.946 : N335 G1 X115.286 Y90.55 E9.16819 *73
09:38:40.962 : ok
09:38:40.962 : N336 G1 X114.714 Y90.55 E9.17797 *77
09:38:40.978 : ok
09:38:40.978 : N337 G1 X114.348 Y90.502 E9.18429 *127
09:38:41.010 : ok
09:38:41.010 : N338 G1 X113.973 Y90.346 E9.19124 *122
09:38:41.025 : ok
09:38:41.027 : N339 G1 X113.651 Y90.099 E9.19818 *115
09:38:41.042 : ok
09:38:41.042 : N340 G1 X113.404 Y89.777 E9.20512 *125
09:38:41.057 : ok
09:38:41.058 : N341 G1 X113.248 Y89.402 E9.21207 *113
09:38:41.074 : ok
09:38:41.074 : N342 G1 X113.2 Y89.036 E9.21839 *122
09:38:41.106 : ok
09:38:41.106 : N343 G1 X113.2 Y54.838 E9.8035 *66
09:38:41.122 : ok
09:38:41.122 : N344 G1 X113.248 Y54.471 E9.80982 *125
09:38:41.137 : ok
09:38:41.140 : N345 G1 X113.404 Y54.096 E9.81677 *123
09:38:42.483 : ok
09:38:42.484 : N346 G1 X113.651 Y53.774 E9.82371 *118
09:38:42.499 : ok
09:38:42.499 : N347 G1 X113.973 Y53.527 E9.83065 *123
09:38:42.515 : ok
09:38:42.516 : N348 G1 X114.348 Y53.372 E9.8376 *69
09:38:42.531 : ok
09:38:42.531 : N349 G1 X114.714 Y53.324 E9.84392 *116
09:38:42.547 : ok
09:38:42.548 : N350 G1 X115.286 Y53.324 E9.8537 *78
09:38:42.563 : ok
09:38:42.564 : N351 G1 X115.652 Y53.372 E9.86003 *117
09:38:42.579 : ok
09:38:42.579 : N352 G1 X116.027 Y53.527 E9.86697 *124
09:38:42.595 : ok
09:38:42.596 : N353 G1 X116.349 Y53.774 E9.87391 *112
09:38:42.611 : ok
09:38:42.612 : N354 G1 X116.596 Y54.096 E9.88085 *118
09:38:42.627 : ok
09:38:42.628 : N355 G1 X116.751 Y54.471 E9.8878 *65
09:38:42.643 : ok
09:38:42.644 : N356 G1 X116.785 Y54.725 E9.89218 *124
09:38:42.659 : ok
09:38:42.659 : N357 G1 X116.429 Y54.828 F12000 *103
09:38:42.675 : ok
09:38:42.676 : N358 G1 X116.433 Y89.012 E10.47705 F1453.5 *50
09:38:42.691 : ok
09:38:42.692 : N359 G1 X116.394 Y89.307 E10.48214 *74
09:38:43.867 : N360 M105 *2
09:38:44.036 : ok
09:38:44.037 : N361 G1 X116.276 Y89.592 E10.48743 *65
09:38:44.072 : ok T:186.5 /190.0 B:50.2 /50.0 @:127
09:38:44.072 : ok
09:38:44.076 : N362 G1 X116.088 Y89.838 E10.49272 *74
09:38:44.084 : ok
09:38:44.085 : N363 G1 X115.842 Y90.026 E10.49802 *68
09:38:44.100 : ok
09:38:44.104 : N364 G1 X115.557 Y90.144 E10.50331 *76
09:38:44.116 : ok
09:38:44.121 : N365 G1 X115.262 Y90.183 E10.50839 *68
09:38:44.133 : ok
09:38:44.137 : N366 G1 X114.738 Y90.183 E10.51736 *77
09:38:44.148 : ok
09:38:44.152 : N367 G1 X114.443 Y90.144 E10.52244 *75
09:38:44.165 : ok
09:38:44.168 : N368 G1 X114.158 Y90.026 E10.52773 *79
09:38:44.180 : ok
09:38:44.183 : N369 G1 X113.912 Y89.838 E10.53303 *66
09:38:44.196 : ok
09:38:44.198 : N370 G1 X113.724 Y89.592 E10.53832 *69
09:38:44.212 : ok
09:38:44.215 : N371 G1 X113.606 Y89.307 E10.54361 *69
09:38:44.228 : ok
09:38:44.231 : N372 G1 X113.567 Y89.012 E10.54869 *70
09:38:44.244 : ok
09:38:44.247 : N373 G1 X113.567 Y54.862 E11.13299 *79
09:38:44.260 : ok
09:38:44.263 : N374 G1 X113.606 Y54.567 E11.13807 *73
09:38:44.276 : ok
09:38:44.279 : N375 G1 X113.724 Y54.281 E11.14336 *72
09:38:45.669 : ok
09:38:45.670 : N376 G1 X113.912 Y54.036 E11.14866 *64
09:38:45.685 : ok
09:38:45.686 : N377 G1 X114.158 Y53.848 E11.15395 *64
09:38:45.701 : ok
09:38:45.702 : N378 G1 X114.443 Y53.729 E11.15924 *72
09:38:45.717 : ok
09:38:45.718 : N379 G1 X114.738 Y53.69 E11.16432 *124
09:38:45.733 : ok
09:38:45.734 : N380 G1 X115.262 Y53.69 E11.17329 *125
09:38:45.749 : ok
09:38:45.749 : N381 G1 X115.557 Y53.729 E11.17838 *69
09:38:45.765 : ok
09:38:45.765 : echo:endstops hit: Y:169.35
09:38:45.766 : N382 G1 X115.842 Y53.848 E11.18367 *73
09:38:45.781 : ok
09:38:45.782 : N383 G1 X116.088 Y54.036 E11.18896 *70
09:38:45.797 : ok
09:38:45.798 : N384 G1 X116.276 Y54.281 E11.19425 *73
09:38:45.813 : ok
09:38:45.814 : N385 G1 X116.394 Y54.567 E11.19954 *65
09:38:45.829 : ok
09:38:45.830 : N386 G1 X116.422 Y54.773 E11.2031 *127
09:38:45.845 : ok
09:38:45.848 : N387 G1 X116.12 Y55.024 F12000 *83
09:38:45.849 : N388 G1 E8.2031 F3900 *20
09:38:45.861 : ok
09:38:45.861 : ok
09:38:45.861 : N389 G92 E0 *101
09:38:45.864 : N390 G1 X130.656 Y38.25 F12000 *93
09:38:47.206 : ok
09:38:47.206 : ok
09:38:47.207 : N391 M105 *12
09:38:47.208 : N392 G1 X69.34 Y38.25 *5
09:38:47.244 : ok T:186.3 /190.0 B:50.3 /50.0 @:127
09:38:47.245 : ok
09:38:47.248 : N393 G1 X82.166 Y54.814 *7
09:38:47.250 : N394 G1 E3.1 F3900 *35
09:38:47.254 : ok
09:38:47.254 : ok
09:38:47.256 : N395 G1 X82.166 Y89.06 E3.68594 F1530 *21
09:38:47.270 : ok
09:38:47.271 : N396 G1 X82.109 Y89.498 E3.6935 *114
09:38:47.286 : ok
09:38:47.287 : N397 G1 X81.916 Y89.962 E3.70209 *75
09:38:47.302 : ok
09:38:47.303 : N398 G1 X81.611 Y90.361 E3.71068 *73
09:38:47.318 : ok
09:38:47.319 : N399 G1 X81.212 Y90.666 E3.71928 *64
09:38:47.334 : ok
09:38:47.335 : N400 G1 X80.748 Y90.859 E3.72787 *70
09:38:47.350 : ok
09:38:47.351 : N401 G1 X80.31 Y90.916 E3.73543 *127
09:38:47.366 : ok
09:38:47.368 : N402 G1 X79.69 Y90.916 E3.74604 *112
09:38:47.382 : ok
09:38:47.383 : N403 G1 X79.252 Y90.859 E3.7536 *119
09:38:47.398 : ok
09:38:47.399 : N404 G1 X78.788 Y90.666 E3.76219 *77
09:38:47.414 : ok
09:38:47.415 : N405 G1 X78.389 Y90.361 E3.77078 *79
09:38:47.430 : ok
09:38:47.431 : N406 G1 X78.084 Y89.962 E3.77938 *78
09:38:47.494 : echo:endstops hit: Y:134.74
09:38:47.494 : ok
09:38:47.498 : N407 G1 X77.891 Y89.498 E3.78797 *64
09:38:47.510 : ok
09:38:47.512 : N408 G1 X77.834 Y89.06 E3.79553 *120
09:38:47.991 : ok
09:38:47.992 : N409 G1 X77.834 Y54.814 E4.38147 *65
09:38:48.247 : ok
09:38:48.248 : N410 G1 X77.891 Y54.376 E4.38902 *64
09:38:48.359 : ok
09:38:48.360 : N411 G1 X78.084 Y53.912 E4.39762 *68
09:38:49.706 : ok
09:38:49.707 : N412 G1 X78.389 Y53.513 E4.40621 *76
09:38:49.722 : ok
09:38:49.723 : N413 G1 X78.788 Y53.207 E4.4148 *114
09:38:49.738 : ok
09:38:49.739 : N414 G1 X79.252 Y53.015 E4.4234 *127
09:38:49.754 : ok
09:38:49.755 : N415 G1 X79.69 Y52.957 E4.43096 *115
09:38:49.770 : ok
09:38:49.771 : N416 G1 X80.31 Y52.957 E4.44157 *112
09:38:49.802 : ok
09:38:49.803 : N417 G1 X80.748 Y53.015 E4.44912 *79
09:38:49.818 : ok
09:38:49.819 : N418 G1 X81.212 Y53.207 E4.45772 *67
09:38:49.834 : ok
09:38:49.835 : N419 G1 X81.611 Y53.513 E4.46631 *66
09:38:49.850 : ok
09:38:49.851 : N420 G1 X81.916 Y53.912 E4.47491 *68
09:38:49.882 : ok
09:38:49.883 : N421 G1 X82.109 Y54.376 E4.4835 *122
09:38:49.898 : ok
09:38:49.899 : N422 G1 X82.159 Y54.759 E4.49012 *65
09:38:49.914 : ok
09:38:49.915 : N423 G1 X81.792 Y54.78 F12000 *98
09:38:49.930 : ok
09:38:49.931 : N424 G1 X81.8 Y89.036 E5.07622 F1530 *32
09:38:49.946 : ok
09:38:49.947 : N425 G1 X81.751 Y89.402 E5.08254 *66
09:38:49.982 : N426 M105 *7
09:38:51.291 : ok
09:38:51.292 : N427 G1 X81.596 Y89.777 E5.08949 *79
09:38:51.327 : ok T:188.2 /190.0 B:50.2 /50.0 @:11
09:38:51.329 : ok
09:38:51.333 : N428 G1 X81.349 Y90.099 E5.09643 *79
09:38:51.340 : ok
09:38:51.344 : N429 G1 X81.027 Y90.346 E5.10337 *74
09:38:51.355 : ok
09:38:51.356 : N430 G1 X80.652 Y90.502 E5.11032 *70
09:38:51.371 : ok
09:38:51.372 : N431 G1 X80.286 Y90.55 E5.11664 *120
09:38:51.387 : ok
09:38:51.388 : N432 G1 X79.714 Y90.55 E5.12642 *116
09:38:51.403 : ok
09:38:51.404 : N433 G1 X79.348 Y90.502 E5.13275 *78
09:38:51.436 : ok
09:38:51.436 : N434 G1 X78.973 Y90.346 E5.13969 *74
09:38:51.452 : ok
09:38:51.452 : N435 G1 X78.651 Y90.099 E5.14663 *71
09:38:51.467 : ok
09:38:51.468 : N436 G1 X78.404 Y89.777 E5.15357 *74
09:38:51.484 : ok
09:38:51.484 : N437 G1 X78.248 Y89.402 E5.16052 *65
09:38:51.515 : ok
09:38:51.516 : N438 G1 X78.2 Y89.036 E5.16684 *76
09:38:51.531 : ok
09:38:51.532 : N439 G1 X78.2 Y54.838 E5.75195 *73
09:38:51.547 : ok
09:38:51.548 : N440 G1 X78.249 Y54.471 E5.75827 *75
09:38:51.563 : ok
09:38:51.564 : N441 G1 X78.404 Y54.096 E5.76522 *67
09:38:52.925 : ok
09:38:52.926 : N442 G1 X78.651 Y53.774 E5.77216 *79
09:38:52.941 : ok
09:38:52.942 : N443 G1 X78.973 Y53.527 E5.7791 *120
09:38:52.957 : ok
09:38:52.958 : N444 G1 X79.348 Y53.372 E5.78605 *78
09:38:52.973 : ok
09:38:52.974 : N445 G1 X79.714 Y53.324 E5.79237 *69
09:38:52.989 : ok
09:38:52.990 : N446 G1 X80.286 Y53.324 E5.80215 *72
09:38:53.005 : ok
09:38:53.006 : N447 G1 X80.652 Y53.372 E5.80848 *69
09:38:53.021 : ok
09:38:53.022 : N448 G1 X81.027 Y53.527 E5.81542 *79
09:38:53.037 : ok
09:38:53.037 : N449 M105 *14
09:38:53.038 : N450 G1 X81.349 Y53.774 E5.82236 *78
09:38:53.074 : ok T:190.0 /190.0 B:50.1 /50.0 @:0
09:38:53.075 : ok
09:38:53.078 : N451 G1 X81.596 Y54.096 E5.8293 *122
09:38:53.085 : ok
09:38:53.086 : N452 G1 X81.751 Y54.471 E5.83625 *71
09:38:53.101 : ok
09:38:53.102 : N453 G1 X81.785 Y54.725 E5.84063 *78
09:38:53.117 : ok
09:38:53.118 : N454 G1 X81.429 Y54.827 F12000 *83
09:38:53.133 : ok
09:38:53.133 : N455 G1 X81.433 Y89.012 E6.4255 F1453.5 *7
09:38:53.149 : ok
09:38:53.151 : N456 G1 X81.394 Y89.307 E6.43059 *74
09:38:54.462 : ok
09:38:54.463 : N457 G1 X81.276 Y89.592 E6.43588 *69
09:38:54.478 : ok
09:38:54.479 : N458 G1 X81.088 Y89.838 E6.44117 *65
09:38:54.494 : ok
09:38:54.495 : N459 G1 X80.842 Y90.026 E6.44647 *66
09:38:54.510 : ok
09:38:54.511 : N460 G1 X80.557 Y90.144 E6.45176 *64
09:38:54.526 : ok
09:38:54.527 : N461 G1 X80.262 Y90.183 E6.45684 *65
09:38:54.542 : ok
09:38:54.543 : N462 G1 X79.738 Y90.183 E6.46581 *75
09:38:54.558 : ok
09:38:54.559 : N463 G1 X79.443 Y90.144 E6.47089 *66
09:38:54.590 : ok
09:38:54.591 : N464 G1 X79.158 Y90.026 E6.47618 *65
09:38:54.606 : ok
09:38:54.607 : N465 G1 X78.912 Y89.838 E6.48148 *69
09:38:54.622 : ok
09:38:54.623 : N466 G1 X78.724 Y89.592 E6.48677 *75
09:38:54.638 : ok
09:38:54.639 : N467 G1 X78.606 Y89.307 E6.49206 *66
09:38:54.654 : ok
09:38:54.656 : N468 G1 X78.567 Y89.012 E6.49714 *72
09:38:54.670 : ok
09:38:54.672 : N469 G1 X78.567 Y54.862 E7.08144 *65
09:38:54.686 : ok
09:38:54.687 : N470 G1 X78.606 Y54.567 E7.08652 *69
09:38:54.703 : ok
09:38:54.703 : N471 G1 X78.724 Y54.281 E7.09181 *66
09:38:56.099 : N472 M105 *6
09:38:56.112 : ok
09:38:56.113 : N473 G1 X78.912 Y54.036 E7.09711 *74
09:38:56.148 : ok T:191.2 /190.0 B:50.0 /50.0 @:0
09:38:56.148 : ok
09:38:56.149 : N474 G1 X79.158 Y53.848 E7.1024 *117
09:38:56.160 : ok
09:38:56.160 : N475 G1 X79.443 Y53.729 E7.10769 *77
09:38:56.176 : ok
09:38:56.176 : N476 G1 X79.738 Y53.69 E7.11277 *121
09:38:56.192 : ok
09:38:56.192 : N477 G1 X80.262 Y53.69 E7.12174 *119
09:38:56.208 : ok
09:38:56.209 : N478 G1 X80.557 Y53.729 E7.12683 *69
09:38:56.224 : ok
09:38:56.224 : N479 G1 X80.842 Y53.848 E7.13212 *72
09:38:56.240 : ok
09:38:56.240 : N480 G1 X81.088 Y54.036 E7.13741 *68
09:38:56.256 : ok
09:38:56.256 : N481 G1 X81.276 Y54.281 E7.1427 *120
09:38:56.272 : ok
09:38:56.272 : N482 G1 X81.394 Y54.567 E7.14799 *75
09:38:56.288 : ok
09:38:56.288 : N483 G1 X81.422 Y54.773 E7.15155 *64
09:38:56.304 : ok
09:38:56.304 : N484 G1 X81.12 Y55.024 F12000 *104
09:38:56.320 : ok
09:38:56.320 : N485 G1 X82.834 Y54.814 *9
09:38:56.336 : ok
09:38:56.337 : N486 G1 X82.891 Y54.376 E7.15911 F1530 *42
09:38:57.697 : ok
09:38:57.698 : N487 G1 X83.084 Y53.912 E7.1677 *114
09:38:57.713 : ok
09:38:57.714 : N488 G1 X83.389 Y53.513 E7.17629 *66
09:38:57.729 : ok
09:38:57.730 : N489 G1 X83.788 Y53.207 E7.18489 *67
09:38:57.745 : ok
09:38:57.746 : N490 G1 X84.252 Y53.015 E7.19348 *68
09:38:57.761 : ok
09:38:57.762 : N491 G1 X84.69 Y52.957 E7.20104 *113
09:38:57.777 : ok
09:38:57.778 : N492 G1 X85.31 Y52.957 E7.21165 *120
09:38:57.793 : ok
09:38:57.794 : N493 G1 X85.748 Y53.015 E7.21921 *70
09:38:57.809 : ok
09:38:57.810 : N494 G1 X86.212 Y53.207 E7.2278 *127
09:38:57.825 : ok
09:38:57.828 : N495 G1 X86.611 Y53.513 E7.2364 *119
09:38:57.841 : ok
09:38:57.842 : N496 G1 X86.916 Y53.912 E7.24499 *64
09:38:57.857 : ok
09:38:57.858 : N497 G1 X87.109 Y54.376 E7.25358 *66
09:38:57.873 : ok
09:38:57.874 : N498 G1 X87.166 Y54.814 E7.26114 *66
09:38:57.889 : ok
09:38:57.890 : N499 G1 X87.166 Y89.06 E7.84708 *123
09:38:57.905 : ok
09:38:57.906 : N500 G1 X87.109 Y89.498 E7.85463 *79
09:38:57.921 : ok
09:38:57.922 : N501 G1 X86.916 Y89.962 E7.86323 *65
09:38:57.953 : ok
09:38:57.956 : N502 G1 X86.611 Y90.361 E7.87182 *67
09:38:57.969 : ok
09:38:57.970 : N503 G1 X86.212 Y90.666 E7.88042 *69
09:38:57.986 : ok
09:38:57.989 : N504 G1 X85.748 Y90.859 E7.88901 *71
09:38:58.017 : ok
09:38:58.019 : N505 G1 X85.31 Y90.916 E7.89657 *120
09:38:58.033 : ok
09:38:58.035 : N506 G1 X84.69 Y90.916 E7.90718 *117
09:38:58.049 : ok
09:38:58.050 : N507 G1 X84.252 Y90.859 E7.91473 *75
09:38:58.065 : ok
09:38:58.066 : N508 G1 X83.788 Y90.666 E7.92333 *67
09:38:58.097 : ok
09:38:58.098 : N509 G1 X83.389 Y90.361 E7.93192 *77
09:38:58.113 : ok
09:38:58.114 : N510 G1 X83.084 Y89.962 E7.94052 *64
09:38:58.129 : ok
09:38:58.130 : N511 G1 X82.891 Y89.498 E7.94911 *74
09:38:58.145 : ok
09:38:58.146 : N512 G1 X82.834 Y89.06 E7.95667 *122
09:38:58.177 : ok
09:38:58.178 : N513 G1 X82.834 Y54.869 E8.54166 *78
09:38:58.193 : ok
09:38:58.194 : N514 G1 X83.2 Y54.838 F12000 *87
09:38:58.209 : ok
09:38:58.210 : N515 G1 X83.248 Y54.471 E8.54799 F1530 *42
09:38:59.154 : N516 M105 *5
09:38:59.554 : ok
09:38:59.555 : N517 G1 X83.404 Y54.096 E8.55493 *66
09:38:59.591 : ok T:190.8 /190.0 B:49.6 /50.0 @:22
09:38:59.591 : ok
09:38:59.592 : N518 G1 X83.651 Y53.774 E8.56187 *64
09:38:59.603 : ok
09:38:59.603 : N519 G1 X83.973 Y53.527 E8.56881 *69
09:38:59.618 : ok
09:38:59.623 : N520 G1 X84.348 Y53.372 E8.57576 *72
09:38:59.635 : ok
09:38:59.635 : N521 G1 X84.714 Y53.324 E8.58208 *70
09:38:59.650 : ok
09:38:59.651 : N522 G1 X85.286 Y53.324 E8.59187 *79
09:38:59.666 : ok
09:38:59.667 : N523 G1 X85.652 Y53.372 E8.59819 *78
09:38:59.683 : ok
09:38:59.683 : N524 G1 X86.027 Y53.527 E8.60513 *69
09:38:59.699 : ok
09:38:59.700 : N525 G1 X86.349 Y53.774 E8.61207 *72
09:38:59.730 : ok
09:38:59.732 : N526 G1 X86.596 Y54.096 E8.61902 *77
09:38:59.746 : ok
09:38:59.747 : N527 G1 X86.751 Y54.471 E8.62596 *74
09:38:59.762 : ok
09:38:59.763 : N528 G1 X86.8 Y54.838 E8.63228 *76
09:38:59.779 : ok
09:38:59.779 : N529 G1 X86.8 Y89.036 E9.2174 *119
09:38:59.794 : ok
09:38:59.795 : N530 G1 X86.752 Y89.402 E9.22372 *66
09:39:01.140 : ok
09:39:01.143 : N531 G1 X86.596 Y89.777 E9.23066 *79
09:39:01.172 : ok
09:39:01.173 : N532 G1 X86.349 Y90.099 E9.2376 *118
09:39:01.188 : ok
09:39:01.189 : N533 G1 X86.027 Y90.346 E9.24455 *79
09:39:01.204 : ok
09:39:01.205 : N534 G1 X85.652 Y90.502 E9.25149 *64
09:39:01.220 : ok
09:39:01.221 : N535 G1 X85.286 Y90.55 E9.25781 *121
09:39:01.242 : ok
09:39:01.243 : N536 G1 X84.714 Y90.55 E9.2676 *73
09:39:01.252 : ok
09:39:01.272 : N537 G1 X84.348 Y90.502 E9.27392 *74
09:39:01.284 : ok
09:39:01.284 : N538 M29 *54
09:39:01.291 : N539 M104 T0 S0 *14
09:39:01.300 : ok
09:39:01.300 : ok
09:39:01.302 : N540 M140 S0 *68
09:39:01.304 : N541 G1 X0 Y0 F4800 *99
09:39:01.304 : N542 M84 *60
09:39:01.316 : ok
09:39:01.316 : ok
09:39:02.210 : N543 M105 *5
09:39:04.036 : ok
09:39:04.036 : echo:endstops hit: X:-0.02
09:39:04.055 : ok T:189.3 /0.0 B:49.5 /0.0 @:0
09:39:05.269 : N544 M105 *2
09:39:05.305 : ok T:188.6 /0.0 B:49.5 /0.0 @:0
09:39:08.325 : N545 M105 *3
09:39:08.350 : ok T:186.8 /0.0 B:49.2 /0.0 @:0
there are 2 echo’s
i printed the cover for the printerhardware and thats what he made
i did not move the PLA - he printes it at these places…
what does it mean?
ok there are 2 connectiings to the endstops but they are connect because he prints not good!! he prints at other places so he hits them…
here is the picture of the normal repetier gcode
We know that it is because of the endstop being triggered. Next question: When printing, is the endstop actually triggered mechanically (by something), or is it a false report?
i checked it and there is no mechanical touch at the endstopps …
he makes the outline correct - there is no hit to the endstopp and when he starts to print the long holes he starts to print at the wrong places …
it ist a false report i think and because of that the printer runs out of the normal printing line and so he really hits the endstops…
i already checked the contacts … everything is ok.
perhaps the endstops broken? but bot (x and y) so could it be that the mainboard is broken?
i dont know what to do anymore…
i made it again - here are the commands
14:22:03.586 : OpenGL version:2.1.0 - Build 8.15.10.2202
14:22:03.587 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_ARB_vertex_array_object
14:22:03.587 : OpenGL renderer:Intel® HD Graphics
14:22:03.587 : Using fast VBOs for rendering is possible
14:22:10.824 : N1 M110 *2
14:22:10.824 : N2 M115 *4
14:22:10.825 : N3 T0 *25
14:22:10.825 : N4 M105 *3
14:22:10.877 : ok
14:22:10.878 : ok
14:22:10.878 : N5 M111 S6 *66
14:22:10.879 : N6 M80 *61
14:22:10.880 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup FIRMWARE_URL:http://www.K8200.eu - velleman.eu PROTOCOL_VERSION:1.0 MACHINE_TYPE:K8200 - 3D PRINTER EXTRUDER_COUNT:1
14:22:10.880 : ok
14:22:10.880 : echo:Active Extruder: 0
14:22:10.880 : ok
14:22:10.883 : N7 M80 *60
14:22:10.892 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:10.892 : N8 M220 S100 *73
14:22:10.892 : ok
14:22:10.892 : ok
14:22:10.893 : N9 M221 S100 *73
14:22:10.896 : ok
14:22:10.896 : ok
14:22:10.896 : ok
14:22:10.896 : N10 M111 S6 *118
14:22:10.897 : N11 M105 *55
14:22:10.912 : ok
14:22:10.913 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:13.933 : N12 M105 *52
14:22:13.942 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:16.990 : N13 M105 *53
14:22:16.999 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:20.052 : N14 M105 *50
14:22:20.062 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:23.108 : N15 M105 *51
14:22:23.120 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:26.165 : N16 M105 *48
14:22:26.178 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:29.220 : N17 M105 *49
14:22:29.237 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:32.287 : N18 M105 *62
14:22:32.366 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:35.339 : N19 M105 *63
14:22:35.354 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:35.804 : Starte Objektanalyse …
14:22:36.445 : Punkte:4587
14:22:36.445 : Kannten:13893
14:22:36.445 : Flächen:9262
14:22:36.445 : Hüllen:1
14:22:36.445 : Objekt ist mannigfaltig.
14:22:36.454 : Analyse beendet.
14:22:36.454 : Starte Objektanalyse …
14:22:36.500 : Punkte:4587
14:22:36.500 : Kannten:13893
14:22:36.500 : Flächen:9262
14:22:36.500 : Hüllen:1
14:22:36.500 : Objekt ist mannigfaltig.
14:22:36.501 : Analyse beendet.
14:22:38.397 : N20 M105 *53
14:22:38.412 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:41.450 : N21 M105 *52
14:22:41.470 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:44.512 : N22 M105 *55
14:22:44.527 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:47.567 : N23 M105 *54
14:22:47.586 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:48.685 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load “C:\Users\Rotzoll\AppData\Local\RepetierHost\slic3r.ini” --print-center 100,100 -o “C:\Users\Rotzoll\AppData\Local\RepetierHost\composition.gcode” “C:\Users\Rotzoll\AppData\Local\RepetierHost\composition.obj”
14:22:50.623 : N24 M105 *49
14:22:50.649 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:51.301 : => Processing triangulated mesh
14:22:53.689 : N25 M105 *48
14:22:53.699 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:56.648 : => Generating perimeters
14:22:56.740 : N26 M105 *51
14:22:56.750 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:22:59.801 : N27 M105 *50
14:22:59.818 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:02.856 : N28 M105 *61
14:23:02.874 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:05.915 : N29 M105 *60
14:23:05.928 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:08.982 : N30 M105 *52
14:23:08.995 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:12.030 : N31 M105 *53
14:23:12.036 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:15.089 : N32 M105 *54
14:23:15.105 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:15.408 : => Detecting solid surfaces
14:23:16.340 : => Preparing infill surfaces
14:23:16.341 : => Detect bridges
14:23:16.436 : => Generating horizontal shells
14:23:16.581 : => Combining infill
14:23:16.581 : => Infilling layers
14:23:18.150 : N33 M105 *55
14:23:18.164 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:21.202 : N34 M105 *48
14:23:21.215 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:24.274 : N35 M105 *49
14:23:24.286 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:27.339 : N36 M105 *50
14:23:27.354 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:30.389 : N37 M105 *51
14:23:30.408 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:33.461 : N38 M105 *60
14:23:33.479 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:36.503 : N39 M105 *61
14:23:36.517 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:37.328 : => Generating skirt
14:23:37.337 : => Exporting G-code to C:\Users\Rotzoll\AppData\Local\RepetierHost\composition.gcode
14:23:39.578 : N40 M105 *51
14:23:39.590 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:42.638 : N41 M105 *50
14:23:42.642 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:45.710 : N42 M105 *49
14:23:45.731 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:48.765 : N43 M105 *48
14:23:48.785 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:51.822 : N44 M105 *55
14:23:51.840 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:54.884 : N45 M105 *54
14:23:54.894 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:23:57.939 : N46 M105 *53
14:23:57.948 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:00.995 : N47 M105 *52
14:24:01.002 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:04.055 : N48 M105 *59
14:24:04.073 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:07.113 : N49 M105 *58
14:24:07.128 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:10.169 : N50 M105 *50
14:24:10.182 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:13.230 : N51 M105 *51
14:24:13.236 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:16.286 : N52 M105 *48
14:24:16.307 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:19.343 : N53 M105 *49
14:24:19.364 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:22.402 : N54 M105 *54
14:24:22.415 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:25.463 : N55 M105 *55
14:24:25.470 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:28.514 : N56 M105 *52
14:24:28.525 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:31.574 : N57 M105 *53
14:24:31.595 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:34.629 : N58 M105 *58
14:24:34.649 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:37.691 : N59 M105 *59
14:24:37.704 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:40.746 : N60 M105 *49
14:24:40.757 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:43.807 : N61 M105 *48
14:24:43.813 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:46.862 : N62 M105 *51
14:24:46.881 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:49.919 : N63 M105 *50
14:24:49.937 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:52.979 : N64 M105 *53
14:24:52.989 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:56.035 : N65 M105 *52
14:24:56.045 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:24:59.091 : N66 M105 *55
14:24:59.100 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:02.147 : N67 M105 *54
14:25:02.155 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:02.648 : Done. Process took 2 minutes and 11.348 seconds
14:25:02.648 : Filament required: 4866.5mm (34.4cm3)
14:25:05.208 : N68 M105 *57
14:25:05.225 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:08.262 : N69 M105 *56
14:25:08.267 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:11.325 : N70 M105 *48
14:25:11.345 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:14.382 : N71 M105 *49
14:25:14.391 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:25:17.437 : N72 M105 *50
14:25:17.452 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:25:20.494 : N73 M105 *51
14:25:20.512 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:25:23.556 : N74 M105 *52
14:25:23.571 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:25:26.611 : N75 M105 *53
14:25:26.631 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:25:29.668 : N76 M105 *54
14:25:29.684 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:25:32.728 : N77 M105 *55
14:25:32.743 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:25:35.785 : N78 M105 *56
14:25:35.808 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:38.840 : N79 M105 *57
14:25:38.848 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:41.896 : N80 M105 *63
14:25:41.908 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:44.957 : N81 M105 *62
14:25:44.968 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:48.012 : N82 M105 *61
14:25:48.027 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:51.075 : N83 M105 *60
14:25:51.090 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:54.132 : N84 M105 *59
14:25:54.147 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:25:57.186 : N85 M105 *58
14:25:57.192 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:00.243 : N86 M105 *57
14:26:00.251 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:03.305 : N87 M105 *56
14:26:03.311 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:06.360 : N88 M105 *55
14:26:06.370 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:09.418 : N89 M105 *54
14:26:09.431 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:12.478 : N90 M105 *62
14:26:12.491 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:15.533 : N91 M105 *63
14:26:15.551 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:18.590 : N92 M105 *60
14:26:18.610 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:21.650 : N93 M105 *61
14:26:21.670 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:24.706 : N94 M105 *58
14:26:24.714 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:27.762 : N95 M105 *59
14:26:27.775 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:30.818 : N96 M105 *56
14:26:30.835 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:33.881 : N97 M105 *57
14:26:33.894 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:36.935 : N98 M105 *54
14:26:36.953 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:39.992 : N99 M105 *55
14:26:40.001 : ok T:24.1 /0.0 B:20.5 /0.0 @:0
14:26:43.054 : N100 M105 *6
14:26:43.078 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:26:46.109 : N101 M105 *7
14:26:46.122 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:26:49.166 : N102 M105 *4
14:26:49.178 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:26:52.221 : N103 M105 *5
14:26:52.242 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:26:55.283 : N104 M105 *2
14:26:55.304 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:26:58.340 : N105 M105 *3
14:26:58.358 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:01.395 : N106 M105 *0
14:27:01.403 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:04.452 : N107 M105 *1
14:27:04.462 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:07.514 : N108 M105 *14
14:27:07.522 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:10.569 : N109 M105 *15
14:27:10.581 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:13.625 : N110 M105 *7
14:27:13.641 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:16.687 : N111 M105 *6
14:27:16.701 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:19.749 : N112 M105 *5
14:27:19.761 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:22.802 : N113 M105 *4
14:27:22.818 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:25.856 : N114 M105 *3
14:27:25.866 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:27:28.913 : N115 M105 *2
14:27:28.926 : ok T:24.1 /0.0 B:20.5 /0.0 @:0
14:27:31.975 : N116 M105 *1
14:27:31.985 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:35.030 : N117 M105 *0
14:27:35.041 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:38.087 : N118 M105 *15
14:27:38.102 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:41.147 : N119 M105 *14
14:27:41.167 : ok T:24.1 /0.0 B:20.5 /0.0 @:0
14:27:44.204 : N120 M105 *4
14:27:44.225 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:47.261 : N121 M105 *5
14:27:47.282 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:50.321 : N122 M105 *6
14:27:50.340 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:27:53.378 : N123 M105 *7
14:27:53.389 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:27:56.433 : N124 M105 *0
14:27:56.449 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:27:59.489 : N125 M105 *1
14:27:59.508 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:28:02.552 : N126 M105 *2
14:28:02.564 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:28:05.606 : N127 M105 *3
14:28:05.627 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:28:08.663 : N128 M105 *12
14:28:08.687 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:28:11.726 : N129 M105 *13
14:28:11.748 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:28:14.781 : N130 M105 *5
14:28:14.792 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:28:17.838 : N131 M105 *4
14:28:17.851 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:28:20.893 : N132 M105 *7
14:28:20.907 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:28:23.955 : N133 M105 *6
14:28:23.970 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:28:27.012 : N134 M105 *1
14:28:27.031 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:28:30.067 : N135 M105 *0
14:28:30.087 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:28:33.124 : N136 M105 *3
14:28:33.131 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:28:36.186 : N137 M105 *2
14:28:36.206 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:28:39.241 : N138 M105 *13
14:28:39.250 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:28:42.298 : N139 M105 *12
14:28:42.314 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:28:45.358 : N140 M105 *2
14:28:45.374 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:28:48.415 : N141 M105 *3
14:28:48.434 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:28:51.471 : N142 M105 *0
14:28:51.490 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:28:54.531 : N143 M105 *1
14:28:54.553 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:28:57.587 : N144 M105 *6
14:28:57.597 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:29:00.643 : N145 M105 *7
14:29:00.653 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:29:03.705 : N146 M105 *4
14:29:03.714 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:29:06.762 : N147 M105 *5
14:29:06.777 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:29:09.816 : N148 M105 *10
14:29:09.837 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:29:12.873 : N149 M105 *11
14:29:12.897 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:29:15.935 : N150 M105 *3
14:29:15.956 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:29:18.990 : N151 M105 *2
14:29:19.000 : ok T:24.1 /0.0 B:20.5 /0.0 @:0
14:29:22.047 : N152 M105 *1
14:29:22.061 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:29:25.109 : N153 M105 *0
14:29:25.117 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:29:28.164 : N154 M105 *7
14:29:28.177 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:29:31.221 : N155 M105 *6
14:29:31.237 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:29:34.275 : N156 M105 *5
14:29:34.280 : ok T:24.0 /0.0 B:20.5 /0.0 @:0
14:29:37.332 : N157 M105 *4
14:29:37.343 : ok T:24.1 /0.0 B:20.5 /0.0 @:0
14:29:40.394 : N158 M105 *11
14:29:40.404 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:29:43.449 : N159 M105 *10
14:29:43.460 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:29:46.506 : N160 M105 *0
14:29:46.520 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:29:49.566 : N161 M105 *1
14:29:49.583 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:29:52.621 : N162 M105 *2
14:29:52.639 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:29:55.685 : N163 M105 *3
14:29:55.704 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:29:58.739 : N164 M105 *4
14:29:58.759 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:30:01.796 : N165 M105 *5
14:30:01.807 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:30:04.851 : N166 M105 *6
14:30:04.867 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:30:07.913 : N167 M105 *7
14:30:07.922 : ok T:24.2 /0.0 B:20.5 /0.0 @:0
14:30:10.970 : N168 M105 *8
14:30:10.986 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:30:14.025 : N169 M105 *9
14:30:14.047 : ok T:24.4 /0.0 B:20.5 /0.0 @:0
14:30:17.082 : N170 M105 *1
14:30:17.091 : ok T:24.3 /0.0 B:20.5 /0.0 @:0
14:30:20.143 : N171 M105 *0
14:30:20.166 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:30:23.199 : N172 M105 *3
14:30:23.220 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:30:26.256 : N173 M105 *2
14:30:26.261 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:30:29.318 : N174 M105 *5
14:30:29.335 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:30:32.375 : N175 M105 *4
14:30:32.399 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:30:35.434 : N176 M105 *7
14:30:35.458 : ok T:24.5 /0.0 B:20.6 /0.0 @:0
14:30:38.488 : N177 M105 *6
14:30:38.552 : ok T:24.5 /0.0 B:20.5 /0.0 @:0
14:30:38.556 : N178 G21 *52
14:30:38.558 : ok
14:30:38.561 : N179 M107 *10
14:30:38.563 : N180 M190 S50 *116
14:30:38.572 : N181 G28 *59
14:30:38.572 : N182 G90 *59
14:30:38.573 : ok
14:30:38.574 : N183 G21 *48
14:38:20.663 : ok
14:38:20.664 : N184 M105 *10
14:38:29.875 : ok
14:38:29.875 : ok
14:38:29.875 : ok
14:38:29.876 : N185 M105 *11
14:38:29.878 : ok T:26.4 /0.0 B:50.0 /50.0 @:0
14:38:29.878 : N186 G92 E0 *104
14:38:29.878 : N187 M82 *55
14:38:29.892 : ok T:26.4 /0.0 B:50.0 /50.0 @:0
14:38:29.892 : ok
14:38:29.892 : ok
14:38:29.900 : N188 M109 S190 *65
14:38:29.903 : N189 G1 E10 F400 *62
14:38:29.904 : N190 G90 *56
14:41:26.557 : ok
14:41:26.557 : ok
14:41:26.557 : ok
14:41:26.558 : N191 M105 *14
14:41:26.558 : N192 G92 E0 *109
14:41:26.559 : N193 M82 *50
14:41:26.579 : ok T:187.3 /190.0 B:50.0 /50.0 @:127
14:41:26.579 : ok
14:41:26.579 : ok
14:41:26.580 : N194 G1 E-3 F3900 *19
14:41:26.584 : N195 G92 E0 *106
14:41:26.589 : ok
14:41:26.589 : ok
14:41:26.590 : N196 G1 Z0.3 F12000 *4
14:41:26.590 : N197 G1 X62.76 Y40.57 *5
14:41:26.605 : ok
14:41:26.605 : ok
14:41:26.606 : N198 G1 E3.1 F3900 *45
14:41:26.621 : ok
14:41:26.622 : Drucke Layer 1 von 200
14:41:26.623 : N199 G1 X63.05 Y40.18 E3.10832 F1530 *36
14:41:26.637 : ok
14:41:26.638 : N200 G1 X63.7 Y39.43 E3.1253 *73
14:41:26.653 : ok
14:41:26.656 : N201 G1 X64.46 Y38.78 E3.14241 *68
14:41:26.669 : ok
14:41:26.670 : N202 G1 X64.84 Y38.5 E3.15048 *121
14:41:26.685 : ok
14:41:26.687 : N203 G1 X65.48 Y38.08 E3.16358 *69
14:41:26.701 : ok
14:41:26.702 : N204 G1 X66.16 Y37.74 E3.17659 *75
14:41:26.717 : ok
14:41:26.717 : N205 M105 *0
14:41:26.720 : N206 G1 X66.6 Y37.55 E3.18479 *116
14:41:26.737 : ok T:187.2 /190.0 B:49.8 /50.0 @:127
14:41:26.737 : ok
14:41:26.738 : N207 G1 X67.49 Y37.24 E3.20091 *64
14:41:26.749 : ok
14:41:26.750 : N208 G1 X68.42 Y37.05 E3.21715 *66
14:41:26.765 : ok
14:41:26.768 : N209 G1 X68.89 Y36.99 E3.22526 *65
14:41:26.781 : ok
14:41:26.783 : N210 G1 X69.74 Y36.94 E3.23983 *69
14:41:26.797 : ok
14:41:26.798 : N211 G1 X130.25 Y36.94 E4.27512 *122
14:41:28.063 : ok
14:41:28.063 : N212 G1 X131.1 Y36.99 E4.28968 *77
14:41:28.158 : ok
14:41:28.159 : N213 G1 X131.57 Y37.05 E4.29779 *116
14:41:28.239 : ok
14:41:28.239 : N214 G1 X132.5 Y37.24 E4.31403 *67
14:41:28.799 : ok
14:41:28.800 : N215 G1 X133.39 Y37.55 E4.33016 *120
14:41:28.895 : echo:endstops hit: Y:40.51
14:41:28.895 : ok
14:41:28.896 : N216 G1 X133.83 Y37.74 E4.33836 *115
14:41:28.911 : echo:endstops hit: Y:40.50
14:41:28.911 : ok
14:41:28.912 : N217 G1 X134.51 Y38.08 E4.35136 *113
14:41:28.927 : ok
14:41:28.928 : N218 G1 X135.15 Y38.5 E4.36446 *67
14:41:28.943 : ok
14:41:28.944 : N219 G1 X135.53 Y38.78 E4.37254 *126
14:41:28.959 : ok
14:41:28.960 : N220 G1 X136.3 Y39.44 E4.38989 *72
14:41:28.975 : ok
14:41:28.976 : N221 G1 X136.96 Y40.21 E4.40724 *126
14:41:28.991 : ok
14:41:28.992 : N222 G1 X137.24 Y40.59 E4.41532 *126
14:41:29.007 : ok
14:41:29.008 : N223 G1 X137.66 Y41.23 E4.42841 *127
14:41:29.023 : ok
14:41:29.024 : N224 G1 X138 Y41.91 E4.44142 *92
14:41:29.039 : ok
14:41:29.040 : N225 G1 X138.19 Y42.35 E4.44962 *124
14:41:29.055 : ok
14:41:29.056 : N226 G1 X138.51 Y43.25 E4.46596 *118
14:41:29.071 : ok
14:41:29.072 : N227 G1 X138.69 Y44.18 E4.48217 *117
14:41:29.780 : N228 M105 *15
14:41:31.282 : ok
14:41:31.282 : N229 G1 X138.75 Y44.66 E4.49045 *123
14:41:31.319 : ok T:189.6 /190.0 B:49.8 /50.0 @:0
14:41:31.319 : ok
14:41:31.320 : N230 G1 X138.8 Y45.5 E4.50484 *124
14:41:31.329 : ok
14:41:31.330 : N231 G1 X138.8 Y154.5 E6.36977 *79
14:41:31.362 : ok
14:41:31.362 : N232 G1 X138.75 Y155.35 E6.38434 *64
14:41:31.410 : ok
14:41:31.410 : N233 G1 X138.69 Y155.82 E6.39244 *64
14:41:31.426 : ok
14:41:31.426 : N234 G1 X138.51 Y156.71 E6.40798 *73
14:41:31.458 : ok
14:41:31.458 : N235 G1 X138.22 Y157.57 E6.42351 *74
14:41:31.490 : ok
14:41:31.491 : N236 G1 X138.04 Y158 E6.43148 *101
14:41:31.506 : ok
14:41:31.506 : N237 G1 X137.68 Y158.73 E6.44541 *65
14:41:31.538 : ok
14:41:31.538 : N238 G1 X137.23 Y159.42 E6.4595 *127
14:41:31.586 : ok
14:41:31.586 : N239 G1 X136.94 Y159.81 E6.46782 *78
14:41:31.602 : ok
14:41:31.603 : N240 G1 X136.3 Y160.55 E6.48456 *121
14:41:31.634 : ok
14:41:31.634 : N241 G1 X135.56 Y161.19 E6.5013 *126
14:41:31.666 : ok
14:41:31.666 : N242 G1 X135.17 Y161.48 E6.50961 *64
14:41:31.682 : ok
14:41:31.682 : N243 G1 X134.48 Y161.93 E6.52371 *69
14:41:31.714 : ok
14:41:31.714 : N244 G1 X133.75 Y162.29 E6.53763 *79
14:41:31.762 : ok
14:41:31.762 : N245 G1 X133.32 Y162.47 E6.54561 *66
14:41:31.778 : ok
14:41:31.780 : N246 G1 X132.45 Y162.77 E6.56135 *68
14:41:31.810 : ok
14:41:31.811 : N247 G1 X131.56 Y162.94 E6.57686 *71
14:41:32.835 : N248 M105 *9
14:41:36.088 : ok
14:41:36.088 : N249 M105 *8
14:41:36.133 : ok T:190.7 /190.0 B:50.0 /50.0 @:7
14:41:36.134 : ok T:190.7 /190.0 B:50.0 /50.0 @:7
14:41:36.135 : N250 G1 X131.08 Y163 E6.58513 *104
14:41:36.144 : ok
14:41:36.145 : N251 G1 X130.24 Y163.05 E6.59953 *68
14:41:36.160 : ok
14:41:36.161 : N252 G1 X69.74 Y163.05 E7.63465 *127
14:41:36.176 : ok
14:41:36.177 : N253 G1 X68.89 Y163 E7.64922 *95
14:41:36.208 : ok
14:41:36.209 : N254 G1 X68.42 Y162.94 E7.65732 *115
14:41:36.224 : ok
14:41:36.228 : N255 G1 X67.49 Y162.75 E7.67356 *125
14:41:36.256 : ok
14:41:36.256 : N256 G1 X66.6 Y162.44 E7.68969 *79
14:41:36.288 : ok
14:41:36.289 : N257 G1 X66.16 Y162.25 E7.69789 *121
14:41:36.304 : ok
14:41:36.305 : N258 G1 X65.48 Y161.91 E7.71089 *124
14:41:36.352 : ok
14:41:36.353 : N259 G1 X64.84 Y161.49 E7.72399 *120
14:41:36.384 : ok
14:41:36.385 : N260 G1 X64.46 Y161.21 E7.73207 *117
14:41:36.400 : ok
14:41:36.401 : N261 G1 X63.69 Y160.55 E7.74942 *113
14:41:36.432 : ok
14:41:36.433 : N262 G1 X63.03 Y159.78 E7.76677 *112
14:41:36.464 : ok
14:41:36.465 : N263 G1 X62.75 Y159.4 E7.77485 *68
14:41:36.480 : ok
14:41:36.481 : N264 G1 X62.33 Y158.76 E7.78794 *121
14:41:36.528 : ok
14:41:36.529 : N265 G1 X61.99 Y158.08 E7.80095 *115
14:41:36.560 : ok
14:41:36.561 : N266 G1 X61.8 Y157.64 E7.80915 *76
14:41:36.576 : ok
14:41:36.577 : N267 G1 X61.49 Y156.75 E7.82528 *121
14:41:36.608 : ok
14:41:36.609 : N268 G1 X61.3 Y155.82 E7.84152 *76
14:41:38.954 : N269 M105 *10
14:41:38.978 : ok
14:41:38.979 : N270 G1 X61.24 Y155.35 E7.84962 *119
14:41:39.016 : ok T:191.1 /190.0 B:50.0 /50.0 @:0
14:41:39.027 : ok
14:41:39.027 : N271 G1 X61.19 Y154.5 E7.86419 *73
14:41:39.042 : ok
14:41:39.043 : N272 G1 X61.19 Y45.5 E9.72912 *120
14:41:39.074 : ok
14:41:39.075 : N273 G1 X61.24 Y44.66 E9.74351 *72
14:41:39.106 : ok
14:41:39.107 : N274 G1 X61.3 Y44.18 E9.75179 *122
14:41:39.122 : ok
14:41:39.123 : N275 G1 X61.47 Y43.29 E9.76729 *78
14:41:39.154 : ok
14:41:39.155 : N276 G1 X61.77 Y42.42 E9.78304 *71
14:41:39.186 : ok
14:41:39.187 : N277 G1 X61.95 Y41.99 E9.79101 *73
14:41:39.202 : ok
14:41:39.203 : N278 G1 X62.31 Y41.26 E9.80494 *64
14:41:39.250 : ok
14:41:39.251 : N279 G1 X62.73 Y40.616 E9.81809 *122
14:41:39.282 : ok
14:41:39.283 : N280 G1 X63.05 Y40.79 F12000 *92
14:41:39.298 : ok
14:41:39.299 : N281 G1 X63.34 Y40.4 E9.82641 F1530 *26
14:41:39.331 : ok
14:41:39.331 : N282 G1 X63.96 Y39.69 E9.84254 *67
14:41:39.363 : ok
14:41:39.363 : N283 G1 X64.67 Y39.07 E9.85866 *73
14:41:39.379 : ok
14:41:39.379 : N284 G1 X65.05 Y38.79 E9.86674 *77
14:41:39.426 : ok
14:41:39.427 : N285 G1 X65.66 Y38.4 E9.87913 *124
14:41:39.458 : ok
14:41:39.459 : N286 G1 X66.31 Y38.08 E9.89152 *65
14:41:39.474 : ok
14:41:39.475 : N287 G1 X66.75 Y37.89 E9.89972 *76
14:41:39.506 : ok
14:41:39.507 : N288 G1 X67.59 Y37.59 E9.91498 *65
14:41:42.008 : N289 M105 *4
14:41:43.783 : ok
14:41:43.784 : N290 G1 X68.46 Y37.41 E9.93018 *78
14:41:43.821 : ok T:191.3 /190.0 B:50.1 /50.0 @:72
14:41:43.821 : ok
14:41:43.822 : N291 G1 X68.93 Y37.35 E9.93829 *78
14:41:43.831 : ok
14:41:43.833 : N292 G1 X69.74 Y37.3 E9.95217 *113
14:41:43.879 : ok
14:41:43.880 : N293 G1 X130.25 Y37.3 E10.98746 *125
14:41:43.911 : ok
14:41:43.912 : N294 G1 X131.06 Y37.35 E11.00135 *77
14:41:43.927 : ok
14:41:43.928 : N295 G1 X131.53 Y37.41 E11.00946 *67
14:41:43.959 : ok
14:41:43.960 : N296 G1 X132.4 Y37.59 E11.02466 *117
14:41:43.991 : ok
14:41:43.992 : N297 G1 X133.24 Y37.89 E11.03992 *77
14:41:44.007 : ok
14:41:44.008 : N298 G1 X133.68 Y38.08 E11.04812 *66
14:41:44.039 : ok
14:41:44.040 : N299 G1 X134.33 Y38.4 E11.06051 *123
14:41:44.071 : ok
14:41:44.072 : N300 G1 X134.94 Y38.79 E11.0729 *115
14:41:44.103 : ok
14:41:44.104 : N301 G1 X135.32 Y39.07 E11.08098 *66
14:41:44.135 : ok
14:41:44.136 : N302 G1 X136.04 Y39.7 E11.09735 *118
14:41:44.151 : ok
14:41:44.152 : N303 G1 X136.67 Y40.42 E11.11371 *64
14:41:44.183 : ok
14:41:44.184 : N304 G1 X136.95 Y40.8 E11.12179 *125
14:41:44.199 : ok
14:41:44.200 : N305 G1 X137.34 Y41.41 E11.13418 *73
14:41:44.231 : ok
14:41:44.232 : N306 G1 X137.66 Y42.06 E11.14657 *67
14:41:44.279 : ok
14:41:44.280 : N307 G1 X137.85 Y42.5 E11.15477 *125
14:41:44.295 : ok
14:41:44.296 : N308 G1 X138.15 Y43.35 E11.1702 *114
14:41:44.327 : ok
14:41:44.328 : N309 G1 X138.33 Y44.23 E11.18556 *76
14:41:45.065 : N310 M105 *5
14:41:46.697 : ok
14:41:46.698 : N311 G1 X138.39 Y44.71 E11.19384 *64
14:41:46.735 : ok T:189.4 /190.0 B:50.1 /50.0 @:127
14:41:46.735 : ok
14:41:46.736 : N312 G1 X138.44 Y45.5 E11.20738 *114
14:41:46.745 : ok
14:41:46.746 : N313 G1 X138.44 Y154.5 E13.07231 *73
14:41:46.777 : ok
14:41:46.780 : N314 G1 X138.39 Y155.31 E13.08619 *115
14:41:46.809 : ok
14:41:46.810 : N315 G1 X138.33 Y155.78 E13.0943 *77
14:41:46.841 : ok
14:41:46.842 : N316 G1 X138.16 Y156.62 E13.10896 *121
14:41:46.857 : ok
14:41:46.858 : N317 G1 X137.88 Y157.43 E13.12363 *113
14:41:46.889 : ok
14:41:46.890 : N318 G1 X137.7 Y157.86 E13.1316 *112
14:41:46.905 : ok
14:41:46.906 : N319 G1 X137.36 Y158.55 E13.14476 *119
14:41:46.953 : ok
14:41:46.954 : N320 G1 X136.94 Y159.2 E13.158 *75
14:41:46.985 : ok
14:41:46.986 : N321 G1 X136.65 Y159.59 E13.16632 *118
14:41:47.001 : ok
14:41:47.002 : N322 G1 X136.04 Y160.29 E13.1822 *70
14:41:47.033 : ok
14:41:47.034 : N323 G1 X135.34 Y160.9 E13.19809 *69
14:41:47.066 : ok
14:41:47.066 : N324 G1 X134.95 Y161.19 E13.2064 *65
14:41:47.081 : ok
14:41:47.082 : N325 G1 X134.3 Y161.61 E13.21965 *73
14:41:47.114 : ok
14:41:47.114 : N326 G1 X133.61 Y161.95 E13.23281 *113
14:41:47.146 : ok
14:41:47.147 : N327 G1 X133.18 Y162.13 E13.24078 *112
14:41:47.178 : ok
14:41:47.178 : N328 G1 X132.36 Y162.41 E13.25561 *121
14:41:47.194 : ok
14:41:47.194 : N329 G1 X131.51 Y162.58 E13.27044 *114
14:41:48.120 : N330 M105 *7
14:41:51.470 : ok
14:41:51.470 : N331 M105 *6
14:41:51.524 : ok T:189.5 /190.0 B:49.8 /50.0 @:117
14:41:51.525 : N332 G1 X131.03 Y162.64 E13.27871 *126
14:41:51.534 : ok
14:41:51.534 : N333 G1 X130.24 Y162.69 E13.29226 *112
14:41:51.550 : ok
14:41:51.551 : N334 G1 X69.74 Y162.69 E14.32738 *72
14:41:51.566 : ok
14:41:51.567 : N335 G1 X68.93 Y162.64 E14.34126 *67
14:41:51.598 : ok
14:41:51.598 : N336 G1 X68.46 Y162.58 E14.34937 *79
14:41:51.614 : ok
14:41:51.615 : N337 G1 X67.59 Y162.4 E14.36457 *127
14:41:51.646 : ok
14:41:51.646 : N338 G1 X66.75 Y162.1 E14.37983 *127
14:41:51.678 : ok
14:41:51.679 : N339 G1 X66.31 Y161.91 E14.38803 *66
14:41:51.694 : ok
14:41:51.695 : N340 G1 X65.66 Y161.59 E14.40042 *75
14:41:51.726 : ok
14:41:51.727 : N341 G1 X65.05 Y161.2 E14.41281 *125
14:41:51.758 : ok
14:41:51.759 : N342 G1 X64.67 Y160.92 E14.42089 *74
14:41:51.790 : ok
14:41:51.791 : N343 G1 X63.95 Y160.29 E14.43726 *66
14:41:51.806 : ok
14:41:51.807 : N344 G1 X63.32 Y159.57 E14.45363 *72
14:41:51.838 : ok
14:41:51.839 : N345 G1 X63.04 Y159.19 E14.4617 *117
14:41:51.870 : ok
14:41:51.871 : N346 G1 X62.65 Y158.58 E14.47409 *78
14:41:51.902 : ok
14:41:51.903 : N347 G1 X62.33 Y157.93 E14.48649 *77
14:41:51.934 : ok
14:41:51.935 : N348 G1 X62.14 Y157.49 E14.49469 *65
14:41:51.950 : ok
14:41:51.951 : N349 G1 X61.84 Y156.65 E14.50995 *67
14:41:51.982 : ok
14:41:51.983 : N350 G1 X61.66 Y155.78 E14.52515 *78
14:41:54.240 : N351 M105 *0
14:41:54.354 : ok
14:41:54.355 : N352 G1 X61.6 Y155.31 E14.53325 *115
14:41:54.392 : ok T:188.8 /190.0 B:49.7 /50.0 @:127
14:41:54.392 : ok
14:41:54.393 : N353 G1 X61.55 Y154.5 E14.54714 *115
14:41:54.402 : ok
14:41:54.403 : N354 G1 X61.55 Y45.5 E16.41206 *69
14:41:54.434 : ok
14:41:54.435 : N355 G1 X61.6 Y44.71 E16.42561 *69
14:41:54.482 : ok
14:41:54.483 : N356 G1 X61.66 Y44.23 E16.43388 *119
14:41:54.498 : ok
14:41:54.499 : N357 G1 X61.83 Y43.38 E16.44871 *122
14:41:54.514 : ok
14:41:54.515 : N358 G1 X62.11 Y42.56 E16.46354 *122
14:41:54.546 : ok
14:41:54.547 : N359 G1 X62.29 Y42.13 E16.47151 *119
14:41:54.562 : ok
14:41:54.563 : N360 G1 X62.63 Y41.44 E16.48467 *125
14:41:54.610 : ok
14:41:54.611 : N361 G1 X63.02 Y40.836 E16.49697 *74
14:41:54.642 : ok
14:41:54.643 : N362 G1 E13.49697 F3900 *31
14:41:54.644 : N363 G92 E0 *97
14:41:54.658 : ok
14:41:54.659 : N364 G1 X117.891 Y54.376 F12000 *105
14:41:54.690 : ok
14:41:54.690 : ok
14:41:54.691 : N365 G1 E3.1 F3900 *45
14:41:54.722 : ok
14:41:54.723 : N366 G1 X118.084 Y53.912 E3.10859 F1530 *30
14:41:54.738 : ok
14:41:54.739 : N367 G1 X118.389 Y53.513 E3.11719 *119
14:41:54.770 : ok
14:41:54.771 : N368 G1 X118.788 Y53.207 E3.12578 *121
14:41:54.802 : ok
14:41:54.803 : N369 G1 X119.252 Y53.015 E3.13438 *126
14:41:54.834 : ok
14:41:54.835 : N370 G1 X119.69 Y52.957 E3.14193 *65
14:41:54.850 : ok
14:41:54.851 : N371 G1 X120.31 Y52.957 E3.15254 *78
14:41:57.295 : N372 M105 *1
14:41:59.126 : ok
14:41:59.127 : N373 G1 X120.748 Y53.015 E3.1601 *74
14:41:59.164 : ok T:190.3 /190.0 B:49.7 /50.0 @:0
14:41:59.175 : ok
14:41:59.175 : N374 G1 X121.212 Y53.207 E3.1687 *73
14:41:59.191 : ok
14:41:59.191 : N375 G1 X121.611 Y53.513 E3.17729 *127
14:41:59.223 : ok
14:41:59.223 : N376 G1 X121.916 Y53.912 E3.18588 *127
14:41:59.255 : ok
14:41:59.255 : N377 G1 X122.109 Y54.376 E3.19448 *120
14:41:59.271 : ok
14:41:59.271 : N378 G1 X122.166 Y54.814 E3.20203 *114
14:41:59.303 : ok
14:41:59.304 : N379 G1 X122.166 Y89.06 E3.78797 *77
14:41:59.335 : ok
14:41:59.336 : N380 G1 X122.109 Y89.498 E3.79553 *122
14:41:59.431 : ok
14:41:59.432 : N381 G1 X121.916 Y89.962 E3.80412 *116
14:41:59.895 : ok
14:41:59.896 : N382 G1 X121.611 Y90.361 E3.81272 *127
14:41:59.991 : echo:endstops hit: Y:57.90
14:41:59.991 : ok
14:41:59.991 : echo:endstops hit: Y:57.88
14:41:59.992 : N383 G1 X121.212 Y90.666 E3.82131 *124
14:42:00.007 : ok
14:42:00.008 : N384 G1 X120.748 Y90.859 E3.8299 *65
14:42:00.023 : ok
14:42:00.024 : N385 G1 X120.31 Y90.916 E3.83746 *71
14:42:00.039 : ok
14:42:00.040 : N386 G1 X119.69 Y90.916 E3.84807 *78
14:42:00.055 : ok
14:42:00.056 : N387 G1 X119.252 Y90.859 E3.85563 *113
14:42:00.071 : ok
14:42:00.072 : N388 G1 X118.788 Y90.666 E3.86422 *120
14:42:00.087 : ok
14:42:00.088 : N389 G1 X118.389 Y90.361 E3.87282 *115
14:42:00.103 : ok
14:42:00.104 : N390 G1 X118.084 Y89.962 E3.88141 *119
14:42:00.119 : ok
14:42:00.120 : N391 G1 X117.891 Y89.498 E3.89001 *121
14:42:00.135 : ok
14:42:00.136 : N392 G1 X117.834 Y89.06 E3.89756 *67
14:42:00.151 : ok
14:42:00.153 : N393 G1 X117.834 Y54.814 E4.4835 *65
14:42:00.167 : ok
14:42:00.169 : N394 G1 X117.884 Y54.43 E4.49012 *67
14:42:00.183 : ok
14:42:00.184 : N395 G1 X118.248 Y54.471 F12000 *102
14:42:00.351 : N396 M105 *11
14:42:01.480 : ok
14:42:01.482 : N397 G1 X118.404 Y54.096 E4.49706 F1530 *16
14:42:01.502 : ok T:192.0 /190.0 B:49.7 /50.0 @:0
14:42:01.502 : ok
14:42:01.503 : N398 G1 X118.651 Y53.774 E4.504 *125
14:42:01.512 : ok
14:42:01.513 : N399 G1 X118.973 Y53.527 E4.51095 *126
14:42:01.528 : ok
14:42:01.529 : N400 G1 X119.348 Y53.372 E4.51789 *118
14:42:01.560 : ok
14:42:01.561 : N401 G1 X119.714 Y53.324 E4.52421 *123
14:42:01.576 : ok
14:42:01.577 : N402 G1 X120.286 Y53.324 E4.534 *126
14:42:01.592 : ok
14:42:01.593 : N403 G1 X120.652 Y53.372 E4.54032 *115
14:42:01.608 : echo:endstops hit: Y:95.81
14:42:01.608 : ok
14:42:01.609 : N404 G1 X121.027 Y53.527 E4.54726 *117
14:42:01.624 : echo:endstops hit: Y:95.77
14:42:01.624 : ok
14:42:01.625 : N405 G1 X121.349 Y53.774 E4.5542 *79
14:42:01.640 : ok
14:42:01.641 : echo:endstops hit: Y:95.78
14:42:01.641 : echo:endstops hit: Y:95.75
14:42:01.641 : N406 G1 X121.596 Y54.096 E4.56115 *116
14:42:01.656 : ok
14:42:01.657 : N407 G1 X121.751 Y54.471 E4.56809 *117
14:42:01.672 : ok
14:42:01.673 : N408 G1 X121.8 Y54.838 E4.57441 *113
14:42:01.688 : ok
14:42:01.691 : N409 G1 X121.8 Y89.036 E5.15953 *127
14:42:01.704 : ok
14:42:01.705 : N410 G1 X121.752 Y89.402 E5.16585 *120
14:42:01.720 : ok
14:42:01.721 : N411 G1 X121.596 Y89.777 E5.17279 *119
14:42:01.736 : ok
14:42:01.737 : N412 G1 X121.349 Y90.099 E5.17973 *126
14:42:01.752 : ok
14:42:01.753 : N413 G1 X121.027 Y90.346 E5.18668 *127
14:42:01.768 : ok
14:42:01.769 : N414 G1 X120.652 Y90.502 E5.19362 *117
14:42:01.784 : ok
14:42:01.785 : N415 G1 X120.286 Y90.55 E5.19994 *77
14:42:01.800 : ok
14:42:01.802 : N416 G1 X119.714 Y90.55 E5.20973 *73
14:42:01.816 : ok
14:42:01.817 : N417 G1 X119.348 Y90.502 E5.21605 *125
14:42:01.832 : ok
14:42:01.834 : N418 G1 X118.973 Y90.346 E5.22299 *117
14:42:01.848 : ok
14:42:01.849 : N419 G1 X118.651 Y90.099 E5.22993 *123
14:42:01.864 : ok
14:42:01.865 : N420 G1 X118.404 Y89.777 E5.23688 *120
14:42:01.880 : ok
14:42:01.881 : N421 G1 X118.248 Y89.402 E5.24382 *126
14:42:01.896 : ok
14:42:01.897 : N422 G1 X118.2 Y89.036 E5.25014 *127
14:42:01.913 : ok
14:42:01.913 : N423 G1 X118.2 Y54.838 E5.83526 *112
14:42:01.928 : ok
14:42:01.929 : N424 G1 X118.241 Y54.526 E5.84064 *116
14:42:01.944 : ok
14:42:01.945 : N425 G1 X118.606 Y54.567 F12000 *98
14:42:02.211 : N426 M29 *56
14:42:03.113 : ok
14:42:03.116 : N427 M104 T0 S0 *0
14:42:03.123 : N428 M140 S0 *75
14:42:03.129 : ok
14:42:03.129 : ok
14:42:03.129 : ok
14:42:03.130 : N429 G1 X0 Y0 F4800 *108
14:42:03.130 : N430 M84 *56
14:42:03.145 : ok
14:42:03.257 : ok
14:42:03.258 : echo:endstops hit: Y:132.93
14:42:03.413 : N431 M105 *1
14:42:03.423 : ok T:193.5 /0.0 B:49.9 /0.0 @:0
14:42:06.467 : N432 M105 *2
14:42:06.483 : ok T:194.7 /0.0 B:50.0 /0.0 @:0
14:42:09.524 : N433 M105 *3
14:42:09.543 : ok T:193.2 /0.0 B:50.2 /0.0 @:0
14:42:12.587 : N434 M105 *4
14:42:12.603 : ok T:191.5 /0.0 B:50.3 /0.0 @:0
again he said he hit the endstop - but there was no hit…
I have exactly the same issue with endstop hits on the y-axis which makes the print finally unusabele.
Discussion about this issue can be found here:
viewtopic.php?f=51&t=9437&p=36985&hilit=endstop+hit#p36985
I am 100% sure that the endstop gets not hit (mechanically) while printing because i have realized the issue once live while printing. Issue could be bad contact inside the microswitch getting hit by vibration.
Or induction from the stepper cable to the switch cable (this was reported in other Reprap Forum with same issue).
When i make a shortcut of the y-switch after initial home calibration the issue does not happen again.
But this is only a (bad) workaround.
@Velleman Support: from my perspective the marlin FW should be modified that the endstop’s are only taken into consideration form initial home calibration. While printing the endstops should not be consideted … there is also no need and savety reason from my perspective because endstop prevents only one direction. In other Reprap Forum some users modified the marlin FW like this on their own to get finally rid of this problem.
