I just put together the K8090 relay board and am now trying to compile software to us it. My laptop is Windows 7 64 bit. I am using Microsoft Visual Basic 2008 Express Edition to compile the program. I add the .net Velleman.Kits.dll to the project and try to compile the following code.
Public Class MainForm
Private Sub btncntrol_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btncntrol.Click
K8090Board1.Port = "com9"
If K8090Board1.Connect() Then
K8090Board1.ToggleRelay(&HFF)
K8090Board1.Disconnect()
End If
End Sub
End Class
I get Unable to load DLL 'K8090D.dll. The specified module could not be found. I get this on the second line IF k8090Board1.connect().
It knows about the dll because it brings up all the K8090Board1.properties
I would appreciate any help if someone has ran into this in the past
