i have Big Problems with my Printer.
I have Printed a Modell than the Printer has Stopped.
And now i Have this Problem
I cant head the bad and extruder but the table i can move.
Sorry for my Bad English
I hope You can Help me
Greetings Klaus
Remove power from the printer.
Unplug Therm 1 and check the resistance should be around 100K.
Thanks for your Fast Message, You mean the resistens form Bed and Extruder?
Therm1 is for the extruder
Therm2 is for the bed.
At room temp they should be around 100K
What are the temps in the software?
i will check it tommorow with the resitance in the software it has at Bed 25° and at Extruder 0°
I have downloaded the drivers from the instructions, i’m currently using the repetier host 0.90C, Baud rate at 250000 and disabled reset on connect. We are using windows 7, 64 bit. I have downloaded arduino and uploaded the marlin.ino file. I have also tried resetting several times. It does go to home via the manual control but wont respond to any of the other manual controls. Does anyone know how to solve this problem? I need an answer as soon as possible as this is a school project.
online checkers with friends invite
Look for error messages in your repetier log.
With The extruder showing 0 °C you should get mintemp triggered.
Check your extruder thermistor wiring for an open circuit.
Since you updated the firmware.
Did you use version 1.0.6?
1.6.x does not work.
You can get it from this link.
http://arduino.cc/download.php?f=/arduino-1.0.6-windows.exe
