I am trying to load filament and i used the instructions but nothing seem to happen.
The temperatur moves between 185 and 189 and the red light on the print head is on.
The filament is in the PTFE TUBE with about 2cm.
if your using PLA it should heat up to 210. question is why it isnt. It dont feed the filament until it have.
Do you have 1 or 2 nozzles? if you have 2 my question is does it do this on both nozzles? if not then im guesing on 1 thing. Termistor issue. messure it so it isnt dmg’d. it should have a set resistance.
// Marlark
