i use the K8064 for 3x 40W halogen lamp. The problem is that the lamps are flickering. this goes most when i dimm the lamps. the flickering is not consistently. it comes unsteady. this is very irritating when i watch tv. what can i do?
sorry for my bad english
regards from germany
Did you test already the kit with a standard incandescent lamp from 60W ?
Check also that you have mount the correct capacitor C12, this must be the 100nF (blue or yellow) and not the 1uF for the USA power supply (red).
