I recently purchased the PCSU1000 and I have been trying to set it up but the software is having trouble seeing the scope although it is plugged in.
I have the latest version of PC LAB2000se installed and every time I open it and try to operate my scope I get this message:
“No hardware response!
Please mare sure that the USB cable is connected.
If connected: Disconnect and reconnect USB cable.
Choose Options | Hardware Setup tto select the operation mode.”
I click “ok”
It tells me the software is now running in Demo Mode because there is no scope present
I click “ok” and click on “Options > Hardware Setup…” and I get this error message saying:
“Load Error
Could not open the DriverLINX driver.
Please run INSTALL_DRV.EXE to install the driver.”
I click “ok”
I have run install_drv.exe multiple times, successfully installed the driver and yet I am still having this same issue. Is there another way I should be approaching this problem? Getting the Driver from another source? uninstall and reinstall it all again?
Any help would be much appreciated, thanks.
