I’m using Delphi XE2 with Windows 7 and with the P8061-2 board. It works with the precompiled demo, but if I compile the demo with my own Delphi program it doesn’t start. It is compiled and when I try to start the compiled executable, I get this message:
it means that it can’t start the application correctly and you need to click ‘Ok’ to close it.
Simply put, what we are trying to get you to do is not mix 32-bit and 64-bit.
So either everything must be 32-bit, or everything must be 64-bit.
If you downloaded a 64-bit driver and dll from our website, then you need to compile as 64-bit. If you use the 32-bit driver and dll, then you need to compile as 32-bit.
Perhaps VEL255 can give you step by step instructions
Off course, I’m sorry, I didn’t think about the driver. I replaced it with the 32bit (old) and now it looks like it works. I will test it some more. For now, thank you very much!
