I’m trying to upload the firmware V2 to my Velleman k8200 but when ever I try to verify the code on arduino an error pops up saying there was a problem moving something to the build folder. The thing it wasn’t able to move changes each time I click it. I tried emptying the temp folder but this made no difference. Can you help?
The heatbed thermistor is also reading 90 degrees while at room temperature. The sensor appears to be working fine so I think the problem is due to the fact that I’ve changed the thermistor recently and it has different characteristics and so the firmware calculates an incorrect temperature. Where in the code do I need to update these values?
I am using 1.0.6 version of arduino. I have managed to upload stuff before, it just doesn’t seem to be working this time. Is there a way for me to download the code from the arduino?
