I’ve assembled the K8800 following the differents steps of the user manual.
I’m new in 3D printing, and I’ve a problem now with the calibration process, as you can see in the 2 attached videos : http://hssforum.com/IMG_5268.MOV http://hssforum.com/Video_1.MOV
It looks like the buildtak is hanging on one of the pegs.
You should correct that.
The videos look like they start in the middle of an operation.
If might help if you start the video at the beginning of the operation.
This is just a guess but are the end stops clean.
Try taking a soft cloth and clean them.
Thanks for your reply.
The operation is the calibration.
The “height calibration” process is well.
But during the “auto calibration” process, the print head is typing the glass like a jackhammer during few seconds.And after that, few seconds later, one of the handle comes off.
When the printer starts does it heat the nozzle to 130C then calibrate (touching the bed with the nozzle) then go to the back of the bed heat up the the rest of the way and then start printing?
Did you download the software from this link (Windows)? https://manuals.velleman.eu/article.php?id=775
After the calibration does it heat the rest of the way to 200c while resting on the bed and then lift to the height that it is trying to print at?
I guess what I am asking is what position does it go to after the calibration?
