Dear all,
I am printing a piece with a size of 120mm on Z-axis :
But my first print was 122, it’s a small difference but it completely make the print unusuable as it needs to fit in another one.
I found some solutions to improve the precision on the Z axis by removing top bearing :
I tried again, same problem with exactly the same 2mm over! It’s good to see that the printer is steady in this difference, but it would be even better to not have it.
Where the problem come from ? Voltage is around 0,5V for the Z-motor. Is there a parameter in Slic3r ?
Thank you in advance for your helps !
Victor
