[quote=“kulla”]I think prints are slightly better, but not that much you would expect, but this is print with 0.4mm nozzle and I still have 0.25mm to test.
Slic3r settings you can find here on forum, there was someone else that put his slow print settings which I’m using.
Nothing needs to be changed, you need to print fan and radiator holder from kurasu and connect everything in the same way as you have it right now. The only extra thing is that fan needs to be always on, but you can take power from the board.[/quote]
I like the fan nozzle you are using with the E3D head. Which one is it? I can only see the opening in your second picture.
