Hey Guys,
This happened to me some time ago…And I’m not sure how it fixed itself.
Now it’s back again…like a ghost from the past…spooky
My 8200 prints are very brittle and not filled properly. My settings on slicer are the same as always.
I’ve just changed out to a new roll of filament, same thing. Brittle and pull apart …totally unusable.
My hot end is around 200 which is normal and bed at around 60. Anyone had this problem :
Help
Is your new roll of the same brand. Some are of very poor quality.
Also check if your nozzle is perfectly clean (try extruding some filament in the air : it should fall straight down and have a diameter of 0.5 mm (if you still have the stock hot end).
