Printing from SD card is very slow
Hy!
I have an K8200 printer with marlin firmware. I use one the PC the Repertier-Host v1.0.6 software. I slice the .stl model with Cura Engine, then save the print and copy manually the gcode to the sd card. My problem is: the repertier software sayd printng time and the real printing time not nearly the same.
Example: The repertier software sayd the printin time is 1 hour 37 minutes. The printer works more than 3 hour.
What is the problem? How can I optimise the software to give me real time? Can everybody help me?
Thanks and best Regards!
Benji
[quote=“Benji1992”]Hy!
Benji[/quote]
This heavily depends on your object.
Generally times for infill are heavily underestimated by the time guess…
Then it is not possible to estimate the real time?
Not really, i think.
But i found it a good rule of thumb on objects with much infill to double the time estimated by the slicer
cheers,
Christian.
Thanks for the reply!
Benji
