Printing on aluminum plate with attached PEI surface, holds like hell
Heatbed MK3
Yes, I too have purchased PEI sheets from Amazon and added them to my 3D prints, it’s the best there is.
I bought here tinyurl.com/js7jnq3
ABS Print on PEI
Why are you still using a brim? If it sticks you shouldn’t need it anymore.
I also ordered a PEI sheet like 2 weeks ago, hopefully I have it by next week
Brim use only occasionally because I have a few rolls low quality filament
Sticks the PEI surface directly to the aluminium heatbed? Works it also for PLA?
No i used 4 mm alu plate and glued PEI with Double-Sided-Adhesive-Transfer-Tape to plate
and then i put aluminum plate instead of glass on a heated bed and fixed her with buckles
ebay.com/itm/3-Sheets-260x30 … SwHnFVmReg
Yes works it also for PLA
