After printjob is done, the extruder-heater stops, the head moves to parkposition and all printhead-fans are stopped immediately. (Only the bottom fan continuous for a moment). Would it not be better to continue the cooling for longer liftime of the printhead parts?
Is it possible do change this? Maybe in the next firmware update?
Issue:
How and where can I permanent change the initial preheat temperatur for pla and abs? Changing under settings doesn’t work ??
Question:
Is it possible to adjust the Thermistor?
[quote=“lem”]1. After printjob is done, the extruder-heater stops, the head moves to parkposition and all printhead-fans are stopped immediately. (Only the bottom fan continuous for a moment). Would it not be better to continue the cooling for longer liftime of the printhead parts?
Issue:
Question:
Mike[/quote]
1: You can manually alter the start or end gcode in the slicer configuration window.
2: You can change the preheat temperature in settings but you need to save the values in the eeprom for the values to be active. You can do this also in the settings menu.
@VEL327:
for question 3 (Is it possible to adjust the Thermistor?)
-> The Display is not indicating the real temperatur! Display shows 210°C, but measured -> ca. 220-225°C !!
-> But in the meantime I have changed the thermistor setting in the Firmware (#define TEMP_SENSOR_0 10 // not 5)
-> now it’s ok an i’m printing pla with 195-200°C (real temeperatur after Firmware change) for best surface results
for question 1: How can i alter the end g-code with a delay of 60s before top-fan cut off? (Like the setting for the bottom fan in Firmware).
Or is ist not required/recommended to cool down the printhead after print Job done?
