after assembling the printer and installing RepetierHost 0.84 I succesfully conected printer and pc (ubuntu linux). But thats all neither the motors turn in manuall mode nor I could switch on the heating nor the fan turns. The printer doesn’t react in any way. Could somebody help me?
thanks for your reply. I’ll check this tomorow evening and will reply. I andjusted the printer like it is mentioned in the manual “de_use_002 - CONNECTING THE PRINTER”. On page 3 is stated that the baud rate must be 57600.
After you press connect in the software try pressing the reset button on the control board.
If this works disconnect the printer from the software.
Go to Config --> Printer Settings and make sure reset on connect is set to Disabled
I changed the baud rate as you told me but nothing changed. I checked in /var/log/syslog that the connection is successfully established. In the manual controll tab there is a debug group. If I press the “ok” button a green led flashes. Thats the only thing that happens.
Non of the leds on the board flash. If I detach the 15 V power supply the red an green led near the usb jack is permanently gleaming. If I attach the power supply they are switched off.
when I connect the usb plug those two leds flash shortly one or two times. After that they are switched off.
In the very last line, on the left side I get a message “connected” (on the right side of this message the temparature is statet with 0°). There is no message in the debug window.
Stop!
The board isn’t defect, I’ll bet.
the magic words are in the first post:
succesfully conected printer and pc ([color=#FF0000]ubuntu linux[/color])
