For the second time now, after about 3 a 4hours printing, the printer just stops.
Repetier does not count down anymore, but gives no error messages.
The extruder and heatbed keep warm and the leds on the printer keep flashing.
Repetier-Host - Manual control tab - OK button
right -bottom corner (Debug Options)
The last button “ok” fakes a receiving ok from the printer. If your printer stalls, it may be simply because the firmware send an ok and only the o or k was received. In that case, hitting ok can restart the printing process.
As said i don’t know if it’s working because i never had the problem
but i remembered this part.
Please try it next time. And if it really works you should try to get bigger distance
between your USB cable and PSU
I replace the usb cable by this one :
The ferrite bulb on the cable protect the datas.
I use a HF headspeaker, and i can listen the electronic of the printer. The plastic enclosure protect the electronic card, but not for Electromagnetic Field. I mean a electomagnetic shield can helping too.
Ill throw in one more potential cause which happened to me; the slicer ran out of memory during slicing and produced an incomplete gcode file. There is a warning in the log when this happens (after slicing, not when printing), but its easily overlooked.
