Printer stops after some hours
My printer is working fine foor smaal object.
But with a large printjob the plastic stops coming out of the nozzle after some hours.
What can be the course of this problem?
I’ve just had the same problem but solved it by printing at 195-200° with 75% flow. So try those settings if you haven’t already.
You may also want to change the retraction to 3 - 4 mm
