so like i said the printer stopped working at sudden. I was printing a thing and everything gone well, then i was going to print another print, and the problems started.
First thing i noticed is that the temperatures wont reach the selected values. The bed temperature is acting strange, the bed heather was always on bad the bed wont reach the temperature, that prematurely was always reached (55C).
Motors on manual wont work. The command is sent but the motors are dead.
The fan on manual is working. I can also turn heaters on and off.
So when I start something for print it say printing but nothing happens.
Is there a way to reset the board or something i can test.
So I reflashed the firmware, and the only problem remains is that the extruder temperature wont reach the selected temperature. Every thing else work (all axes, fan, heaters,… its all works in manualy). So if i select 210C it reaches 205C, if I choose 200C its reaches 195C and so on. Always stops heating 5C before it reaches the desired temperature. So it seems that the board stops the extruder heater before it reaches the selected temperature. I cant figure why.
So when the bed temperature is reached, then the extruder moves in the home position and then the printer waits for the extruder to reach the temperature but its never reached because of the problem described before.
For me its seem like a settings problem, the same thing happens in Cura 3D and also in Repetier.
[quote=“Wrong Way”]
I have also heard that Internet Explorer sometimes has an issue when downloading the firmware you might try another web browser.[/quote]
That’s why i only use Firefox
[quote=“Wrong Way”]
You night try reloading the EEPROM values as well.[/quote]
Good point Wrong Way!
After a firmware reflash that is absolutely necessary!
In the firmware settings of repetier just press reload default values.
This will load the eeprom settings from the new compiled firmware.
After thst save them to eeprom and you will be fine.
The temp behavior may be caused by a slightly unstable hotend thermistor.
