Interesting new problem with my printer. Repetier is determined that my extruder is at 141C when its off. If I begin heating up the extruder, the temperature reading will not move until it passes 140 and with go up to any set temperature without issue. If i turn it off, it will show it cooling down just like it always did. Once it hits 140 it won’t read any lower, but it is still cooling and I can touch it no problem after a few minutes.
I tested the thermistor with my multimeter and got a 99.4 Ohm reading, which seems to be fine to me. No wiring faults visible and the temperature (when heated) is correct. I measured it with a secondary thermometer. It prints perfectly fine as well.
I’m starting to think it’s an issue with repetier or the firmware, not the hardware. Any ideas or has anyone encountered this before?
I Just installed an E3D V6 Hotend and installed the thermistor it came with. do I need to edit the firmware to configure it for the new thermistor?
