I built my K8600 and it works fine with the Spoolholder file.
I installed the repetier software but cant get the Printer settings for the Nano.
Is there a file with the settings available?
Regards
Regards
You can download the customized Repetier for the K8600 from this link
http://www.vellemanusa.com/support/downloads/?code=K8600 it should have everything you need to start printing.
I installed the Programm again, but I only get the default Printer settings.
I dont get the Vertex Nano print setting!
Is there a hard compy of the Vertex Nano print and filament settings?
Hi clexi,
There is no file with the printer settings. All is saved in the registry.
Only the slicr-settings with printing and filament settings are saved in files.
Stored at: \AppData\Local\VertexNanoRepetier
Try installing with administration rights
