I’ve had my printer working for a while and things were working fine until today. I went through the usual connection procedure but could not get the printer to move in any axis. I do see the temperature curve respond to an increase in temperature so I assume all the connections are ok.
I powered down the PC and the printer a couple of time with no change to the problem.
I’m running Repetier V0.90 & Slic3r 0.9.10b and I’m attaching a copy of the log;
https://dl.dropboxusercontent.com/u/32176304/8200%20Log.txt
It shows the printer was stopped due to errors but I have no idea what those errors are or what to do to correct the problem.
Any help would be greatly appreciated.
Tom
